信步科技SV-OPS-H270嵌入式主板介绍
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2*Mini-PCIe, DC 19V Input
  • Supports Intel® Kaby Lake & 7th Gen Core i3/i5/i7 CPU (LGA1151) with Intel H270 chipset
  • Supports 4K UHD display
  • Supports dual display of VGA and HDMI
  • Provides OPS-C+ port which can expand more display port (use OPS Extension Modules)
  • 1*1000 Mbps LAN and 2*Mini-PCIe
  • Supports DC 19V Input
规格
General
CPU Intel® Kaby Lake Pentium®/ Celeron®/ 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® H270 Chipset, TDP 6W
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0 (22Pin), 1*mSATA
Expansion Interface
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported)
1*OPC-C+ Port
BIOS AMI UEFI BIOS
System Windows 10 x64, Linux
I/O Interface
Serial Port 1*RS232
USB 2*USB 3.0, 4*USB 2.0 (6*on rear I/O)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 Null
Parallel Port Null
GPIO Null
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 170*190mm
Power Input DC 12-19V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
