信步科技OPS-H110主板介绍英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, OPS-C+, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 12~19V Input
  • Supports Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with Intel H110 chipset
  • Provides OPS-C+ port for Digital White Board
  • Supports dual display of VGA, HDMI and DP, UHD 4K
  • 1*1000 Mbps LAN and 2*Mini-PCIe
  • Supports DC 12-19V Input
规格
General
CPU Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® H110 Chipset, TDP 6W
Memory Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM
Storage 1*SATA 3.0 (22Pin), 1*mSATA
Expansion Interface
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported)
1*OPC-C+ Port
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 1*RS232
USB 2*USB 3.0+4*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 Null
Parallel Port Null
GPIO Null
Feature Interface IRM (Infrared Receiver Module)
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 4096*2160@30Hz
1*OPS_HDMI: max resolution up to 4096*2160@30Hz
1*OPS_DP: max resolution up to 4096*2304@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 170*190mm
Power Input DC 12-19V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
