信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
  • Supports Intel 4th Gen Core i3/i5/i7 CPU and Pentium/ Celeron LGA1150 CPU with Intel H81 chipset
  • 6*COM, 10*USB, 1*100 Mbps LAN
  • Supports dual display of VGA and HDMI
  • 1*PCI-E 16X, 1*Mini-PCIe
规格
General
CPU Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset Intel® H81 Chipset, TDP 4.1W
Memory Up to 8 GB DDR3 1600/1333 MHz, 1*DIMM
Storage 2*SATA 3.0, 2*SATA 2.0
Expansion Interface 1*PCI-E 16X, 1*Mini-PCIe (Wifi Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 6*RS232 (COM2 RS485 optional)
USB 2*USB 3.0, 8*USB 2.0 (4*on rear I/O, 6*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 2*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
