信步科技SV1-18016P-B主板规格英文版
Intel Bay Trail J1800处理器, 6*COM, 1*LAN, 1*Mini-PCIe, DC 12V供电, Mini-ITX (170*170mm)
  • 采用Intel Bay Trail J1800处理器
  • 提供6*COM, 9*USB, 1*百兆LAN
  • 提供1*VGA, 1*HDMI, 1*LVDS, 支持多种双屏异显
  • 提供1*Mini-PCIe (支持mSATA/3G/4G)
  • 采用DC 12V供电
规格
General
CPU Intel® Bay Trail J1800 CPU, Dual-core, up to 2.58 GHz, TDP10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 1*Mini-PCIe (mSATA/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 6*RS232 (COM2 RS485, COM3 TTL optional)
USB 9*USB 2.0 (4*on rear I/O, 5*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
1*HDMI: max resolution up to 2560*1600@60Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
