信步科技NVR SV4-H11A6主板规格英文版
Intel 6/7代CoreTM i3/i5/i7处理器 (LGA1151), 18*SATA, 2*Intel千兆LAN, 1*PCI-E 16X, 1*Mini-PCIe, ATX (275*210mm)
  • 支持Intel 6/7代Core i3/i5/i7处理器 (LGA1151)
  • 采用Intel H110芯片组
  • 提供4*Mini-SAS (16*SATA), 1*SATA 3.0, 2*Intel千兆LAN
  • 提供1*PCI-E 16X, 1*Mini-PCIe
  • 提供1*VGA, 2*HDMI, 支持多种双屏异显
规格
General
CPU Intel® Pentium®/ Celeron®/ 6th and 7th Generation CoreTM i3/i5/i7 CPU, LGA1151
Chipset Intel® H110 Chipset, TDP 6W
Memory Up to 32 GB DDR4 2133/1866 MHz, 2*DIMM
Storage 4*Mini-SAS (16*SATA), 1*SATA 3.0, 1*mSATA/M.2
Expansion Interface 1*PCI-E 16X, 1*Mini-PCIe (mSATA/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Server 2008/2012, Linux
I/O Interface
Serial Port 2*RS232 (1*RS485 optional)
USB 4*USB 3.0, 5*USB 2.0 (4*on rear I/O, 4*header,1*on board connector )
Ethernet 2*Intel® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO+4 in/ 2 out Opto-Isolated GPIO
Feature Interface
1*Front Audio
1*Buzzer Mute
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
2*HDMI: max resolution up to 4096*2160@30Hz
Multiple Display Dual
Mechanical & Environment
Dimension ATX, 275*210mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
