信步科技SV3-26026主板规格英文版
Intel Atom N2600处理器, 6*COM, 2*LAN, 2*Mini-PCIe, DC 12V供电, 3.5英寸 (146*105mm)
  • 采用Intel Atom N2600处理器
  • 提供6*COM, 6*USB, 2*千兆LAN
  • 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
  • 提供1*VGA, 1*LVDS, 支持双屏异显
  • 3.5英寸 (146*105mm)
规格
General
CPU Intel® AtomTM N2600 CPU, Dual-core, 1.6 GHz, TDP 3.5W
Chipset Intel® NM10 Chipset, TDP1.5W
Memory Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 6*RS232 (COM6 RS485 optional)
USB 6*USB 2.0 (2*on rear I/O, 4*header)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS: Dual Channel 24bit, max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 3.5'', 146*105mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
信步科技
