信步科技SV6-B752C主板规格英文版
Intel LGA1155全系列处理器, 12*COM, 12*USB, 2* LAN, 2*PCI-E, 2*PCI, 2*VGA, 1*DVI
  • 支持Intel 2代, 3代Core i3/i5/i7处理器及全系列LGA1155处理器
  • 采用Intel B75芯片组
  • 提供12*COM, 12*USB, 2*千兆LAN
  • 提供2*VGA, 1*DVI, 支持三屏异显
  • VTM异步输出电路, 支持板上语音切换
  • 提供1*PCI-E 16X, 1*PCI-E 4X, 2* PCI
  • 提供1*Mini-PCIe (支持Wifi/3G/4G)
规格
General
CPU
Intel® Pentium®/ Celeron®/ 2nd and 3rd Generation CoreTM i3/i5/i7 CPU, LGA1155
Chipset
Intel® B75 Chipset, TDP 6.7W
Memory
Up to 16 GB DDR3 1600/1333/1066 MHz, 2*DIMM
Storage
1*SATA 3.0, 4* SATA 2.0
Expansion Interface
1*PCI-E 16X, 1*PCI-E 4X, 2* PCI, 1*Mini-PCIe (Wifi/3G/4G Supported)
BIOS
AMI UEFI BIOS
System
Windows XP/7/8/10, Linux
I/O Interface
Serial Port
12*RS232 (COM2 RS485 optional)
USB
4*USB 3.0, 8*USB 2.0 (6*on rear I/O, 6*header)
Ethernet
2*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2
1*PS/2 (Keyboard Supported)
Parallel Port
1*LPT
GPIO
8 programmable GPIO
Feature Interface
Null
Display
Display Interface
2*VGA: max resolution up to 1920*1200@60Hz
1*DVI: max resolution up to 1920*1200@60Hz
Multiple Display
Triple
Mechanical & Environment
Dimension
Micro-ATX, 244*244mm
Power Input
ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
信步科技
信步科技
