信步科技SV1a-25514P-C主板规格英文版
Intel Atom D2550处理器, 4*COM, 1*LAN, 1*Mini-PCIe, DC 12V供电
  • 采用Intel Atom D2550处理器
  • 采用Intel NM10芯片组
  • 提供4*COM, 8*USB, 1*百兆LAN
  • 提供1*VGA, 1*LVDS, 支持双屏异显
  • 提供1*Mini-PCIe (支持mSATA)
  • 采用DC 12V供电
  • 薄型Mini-ITX, 板身厚度≤17mm
规格
General
CPU Intel® AtomTM D2550 CPU, Dual-core, up to 1.86 GHz, TDP 10W
Chipset Intel® NM10 Chipset, TDP 1.5W
Memory Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 1*Mini-PCIe (mSATA Supported)
BIOS AMI UEFI BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 4*RS232 (COM3 TTL optional)
USB 8*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifer
PS/2 1*PS/2 header (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface 1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS: Single Channel 24bit, max resolution up to 1440*900@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
