信步科技SV3-19026P-B主板规格英文版
Intel Bay Trail J1900处理器, 6*COM, 11*USB, 2*LAN, 2*Mini-PCIe, DC 12V供电
  • 采用Intel Bay Trail J1900处理器
  • 提供6*COM, 11*USB, 2*千兆LAN
  • 提供1*VGA, 1*eDP, 支持双屏异显
  • 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
  • 采用DC 12V供电
  • 3.5英寸 (146*102mm)
规格
General
CPU Intel® CeleronTM J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W
Chipset Null
Memory Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM
Storage 1*SATA 2.0, 1*mSATA
Expansion Interface 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux, Android
I/O Interface
Serial Port 6*RS232
USB 11*USB 2.0 (11*header)
Ethernet 2*Realtek® PCI-E LAN for 1000Mbps
Audio
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports
1*Amplifier
PS/2 Null
Parallel Port Null
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 2560*1600@60Hz
1*eDP: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension 3.5'', 146*102mm
Power Input DC 12V
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
嵌入式主板
