如何将Arduino的GPS模块连接和使用
1.2w人已加入
步骤1:电路连接
BLACK线到Ultimate板的Gnd连接
RED线到Ultimate板的5V连接
BLUE线到Ultimate板的RxD连接
GREEN线到Ultimate板的TxD连接
WHITE线到Ultimate板的PPS连接
根据我们的代码
connect
RXPin电路板到digitalPin 4,
电路板到digitalPin 3的TXPin
Vcc到5v,GND到GND
步骤2:编程
首先需要一个库:
您可以从此处下载
在arduino中安装库之后,打开 DeviceExample.ino 来自示例》 tinyGPS ++
或简单地复制以下代码。
#include
#include
* https://alaspuresujay.github.io/
* follow me on instagram https://www.instagram.com/alaspuresujay
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
9600-baud serial GPS device hooked up on pins 4(rx) and 3(tx)。
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
void setup()
Serial.begin(115200);
ss.begin(GPSBaud);
Serial.println(F(“DeviceExample.ino”));
Serial.println(F(“A simple demonstration of TinyGPS++ with an attached GPS module”));
Serial.print(F(“Testing TinyGPS++ library v. ”)); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F(“by Sujay Alaspure”));
Serial.println();
void loop()
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() 》 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() 》 5000 && gps.charsProcessed() 《 10)
Serial.println(F(“No GPS detected: check wiring.”));
while(true);
void displayInfo()
float latt=gps.location.lat();
Serial.print(gps.location.lat(),10);
Serial.print(F(“,”));
Serial.print(gps.location.lng(), 10);
Serial.print(“ ”);
Serial.print(latt,10);
Serial.print(F(“Location: ”));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(gps.location.lng(), 6);
else
Serial.print(F(“INVALID”));
Serial.print(F(“ Date/Time: ”));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F(“/”));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
else
Serial.print(F(“ ”));
if (gps.time.isValid())
if (gps.time.hour() 《 10) Serial.print(F(“0”));
Serial.print(gps.time.hour());
Serial.print(F(“:”));
if (gps.time.minute() 《 10) Serial.print(F(“0”));
Serial.print(gps.time.minute());
if (gps.time.second() 《 10) Serial.print(F(“0”));
Serial.print(gps.time.second());
Serial.print(F(“。”));
if (gps.time.centisecond() 《 10) Serial.print(F(“0”));
Serial.print(gps.time.centisecond());
else
Serial.println();
步骤3:注意:
请将GPS模块放在房屋外面或窗户旁边。
廉价的GPS模块例如VK16E的1pps信号精度不高。
您可能会发现,与许多使用贴片天线的GPS模块一样,GPS模块可能需要放在窗户旁边或外面。 GPS信号的强度似乎会根据位置和周围建筑物等的不同而有很大差异。根据您的棚屋布局和接地情况,离极限套件越远,GPS模块也可能会受益。因此,您可能需要使用几米长的电线将GPS模块连接到套件。我建议在屏幕连接到Gnd的情况下使用屏蔽电缆。 4)
该模块具有绿色LED(如上图所示),在GPS模块搜索卫星锁定时该LED持续亮起,并且在锁定时以每秒1脉冲的频率闪烁。/strong》
责任编辑:wv
