DALI 48V驱动
DALI-CC-30W-48V技术手册
张工-13923882807-QQ:813267849
产品名称:DALI-CC-30W-48V
支持协议:IEC 62386-101:2018,IEC 62386-102:2018,IEC 62386-207:2018
产品型号:DALI-CC-30W-48V
调光方式:DALI模拟调光
外形结构:单面元器件
模块尺寸:125mm(长)×14.5mm(宽)×7.7mm(厚)
认证:过DALI2.0认证
Item
Value
Remark
Input
DC voltage input
48V
Polarity-free
Nominal frequency
0Hz
DC voltage range
47~50V
Nominal current
0.65A
Full   load@100% dimming level
Efficiency
92%
No-load power
<0.3W
Stand-by power
<0.2W
Output
Nominal voltage range
10~40V
Maximum voltage
48Vdc
Nominal current range
700mA
DIP Switch (1: ON 2: ON 3: ON)
650mA
DIP Switch (1: ON 2: ON 3: OFF)
600mA
DIP Switch (1: ON 2: OFF 3: ON)
550mA
DIP Switch (1: ON 2: OFF 3: OFF)
500mA
DIP Switch (1: OFF 2: ON 3: ON)
450mA
DIP Switch (1: OFF 2: ON 3: OFF)
400mA
DIP Switch (1: OFF 2: OFF 3: ON)
350mA
DIP Switch (1: OFF 2: OFF 3: OFF)
Current accuracy
± 5%
Dimming
Dimming control
DALI 2
Dimming technique
Hybrid Dimming
1~12.5%: PWM
12.5~100%: Amplitude
Dimming range
1~100%
Galvanic isolation
YES
Basic insulated to Dali
Protections
Short-circuit
YES
DALI status feedback
Open-circuit
YES
Overload
YES
Overtemperature
YES
Environment
Ambient temperature range ta
-20°C...+50°C
Maximum tc point temperature tc
88°C
@ta
Storage temperature range
-40°C…+85°C
Relative humidity
10…95%
Environmental rating
Indoor
Expected lifetime
>50000h
ta 50 °C
  • 相关推荐
