Firefly-RK3128开发板UART接口介绍
UART 使用
板载资源介绍
Firefly-RK3128 开发板内置 3 路 UART,分别为 uart0,uart1,uart2。uart0 用于蓝牙数据传输,如果要使用 uart0,必须关掉蓝牙,才可以使用扩展槽上的 UART0 针脚。uart1, 因为存在以下复用:
  • BT_HOST_WAKE/SPI_TXD/UART1_TX
  • BT_WAKE/SPI_RXD/UART1_RX
  • WIFI_REG_ON/SPI_CSN0/UART1_RTS
若要使用 uart1, 必须关掉蓝牙和 SPI 功能,这样才可以使用扩展槽上的 SPI_RX 和 SPI_TX 针作 UART1_RX 和 UART1_TX 使用。uart2 一般用做调试串口,但同样存在复用,也就是说 TF 卡与调试串口不可以同时使用:
  • SDMMC_D0/UART2_TX
  • SDMMC_D1/UART2_RX
uart1 和 uart2 有 32 字节的 FIFO 收发缓冲区,uart0 则要有双 64 字节的 FIFO 用作蓝牙数据收发。所有 uart 均支持 5 位、6 位、7 位、8 位数据收发和 DMA 操作。
配置 DTS 节点
文件 kernel/arch/arm/boot/dts/rk312x.dtsi 中已经有 uart 相关节点定义,如下所示:
uart0: serial@20060000 { compatible = "rockchip,serial"; reg = <0x20060000 0x100>; interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart0>, <&clk_gates8 0>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; dmas = <&pdma 2>, <&pdma 3>;#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; status = "disabled"; }; uart1: serial@20064000 { compatible = "rockchip,serial"; reg = <0x20064000 0x100>; interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart1>, <&clk_gates8 1>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; dmas = <&pdma 4>, <&pdma 5>;#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>; status = "disabled"; };
配置 uart0
用户只需在 kernel/arch/arm/boot/dts/rk3128-fireprime.dts 文件中打开 uart0 ,并关掉蓝牙,如下所示:
&uart0 { status = "okay"; dma-names = "!tx", "!rx"; pinctrl-0 = <&uart0_xfer &uart0_cts>;}; wireless-bluetooth { compatible = "bluetooth-platdata"; ... status = "disabled"; };
配置 uart1
用户只需在 kernel/arch/arm/boot/dts/rk3128-fireprime.dts 文件中打开 uart1 ,并关掉蓝牙和 SPI,如下所示:
//... wireless-bluetooth { compatible = "bluetooth-platdata"; ... status = "disabled"; };//... &spi0 { status = "disabled"; }; &uart1 { status = "okay"; dma-names = "!tx", "!rx"; pinctrl-0 = <&uart1_xfer &uart1_cts>; };
编译并烧写内核
将串口驱动编译到内核中,在 kernel 目录下执行如下命令:
make firefly_defconfig make rk3128-fireprime.img -j4
把 kernel 目录下生成的 kernel.img 和 resource.img 烧录到开发板中即可。
测试串口通讯
配置好串口后,用户可以通过主机的 USB 转串口适配器向开发板的串口收发数据,以 uart0 为例,步骤如下:
(1) 连接硬件
将开发板 uart0 的 TX、RX、GND 引脚分别和主机串口适配器的 RX、TX、GND 引脚相连。注意:如果是使用 Firefly 的串口适配器,则是 TX 对 TX,RX 对 RX 连接。
(2) 打开主机的串口终端
在终端打开 kermit,并设置波特率:
$ sudo kermit C-Kermit> set line /dev/ttyUSB0 C-Kermit> set speed 9600 C-Kermit> set flow-control none C-Kermit> connect
  • /dev/ttyUSB0 为 USB 转串口适配器的设备文件
  • uart0 的波特率默认为 9600
(3) 发送数据
uart0 的设备文件为 /dev/ttyS0。在设备上运行下列命令:
echo firefly uart test... > /dev/ttyS0
主机中的串口终端即可接收到字符串“firefly uart test…”
(4) 接收数据
首先在设备上运行下列命令:
cat /dev/ttyS0
然后在主机的串口终端输入字符串 “Firefly uart test…”,设备端即可见到相同的字符串。要改变 uart0 的波特率,例如 115200,可以运行以下命令:
stty -F /dev/ttyS0 115200
