STM32针对字库的调用方法——适用于最基本的16点阵字库、16x16汉字库等应用
今日头条
1092人已加入
       本例用STM32单片机普通IO口模拟SPI的方式来读取高通字库GT20L16S1Y。本款芯片适合最基本的16点阵字库、16x16汉字库、一级字库、单片机字库应用,该芯片支持gb2312点阵和基本的ASCII编码的字符集,采用SPI协议的接口来读取芯片内的数据。封装为SOT23-6,体积较小,适合任意大小的设备。
       本例中使用的单片机型号是STM32F103VDT6,字库使用的引脚是PA口的4,5,6,7脚,首先我们对这个单片机的系统时钟进行设置。进行系统时钟设置后才能开启端口的时钟。具体如下例所示。
void SystemInit (void)
    RCC->CR |= (uint32_t)0x00000001;
    RCC->CFGR &= (uint32_t)0xF0FF0000;
    RCC->CR &= (uint32_t)0xFEF6FFFF;
    RCC->CR &= (uint32_t)0xFFFBFFFF;
    RCC->CFGR &= (uint32_t)0xFF80FFFF;
    RCC->CIR = 0x009F0000;
    RCC->CFGR2 = 0x00000000;
    SystemInit_ExtMemCtl();
    SetSysClock();
    SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
设置好时钟后开始初始化STM32的IO口,如下例所示
#define  CLK_H     GPIO_SetBits(GPIOA,GPIO_Pin_5)
#define  CLK_L     GPIO_ResetBits(GPIOA,GPIO_Pin_5)
#define  SO_H      GPIO_SetBits(GPIOA,GPIO_Pin_7)
#define  SO_L      GPIO_ResetBits(GPIOA,GPIO_Pin_7)
#define  CS_H      GPIO_SetBits(GPIOA,GPIO_Pin_4)
#define  CS_L      GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define  SI        GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)
void GenitopZkInit(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
    GPIO_Init(GPIOA,&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
好了,下面开始用IO口模拟SPI来读写字库
发送0X03及计算出来的字库地址
void GenitopZk_Address(unsigned char AddH,unsigned char AddM,unsigned char AddL)
    Send_Byte(0x03);
    Send_Byte(AddH);
    Send_Byte(AddM);
    Send_Byte(AddL);
从字库指定的地址address读出一个字节的数据出来
unsigned char ZkReadOneByte(unsigned long int address)
    unsigned char dat=0x00,AddH,AddM,AddL;
    CS_L;
    AddH=address>>16;
    AddM=address>>8;
    AddL=address;
    GenitopZk_Address (AddH,AddM,AddL);
    dat=ReadByte();
    CS_H;
    return dat;
从字库指定的地址读出N个字节的数据
Void ZkReadNByte(unsigned long int address,unsigned char byte_long,unsigned char *p_arr)
    unsigned char AddH,AddM,AddL;
    unsigned int j;
    CS_L;
    AddH=address>>16;
    AddM=address>>8;
    AddL=address;
for(j=0;j
    p_arr[j]=ReadByte();
    CS_H;
该函数向字库发送数据
void Send_Byte(unsigned char out)
    unsigned char i=0;
for(i=0;i<8;i++)
    CLK_L;
    if(((out<
        SO_L;
  else
      SO_H;
  CLK_H;
该函数从字库接收数据
u8 ReadByte(void)
    u8 i;
    u8 dat;
    CLK_H;
for(i=0;i<8;i++)
    CLK_L;
    dat=dat<<1;
if(SI)
    dat=dat|0x01;
    else
    dat&=0xfe;
    CLK_H ;
return dat;
读取汉字并显示的函数,参数M是指汉字机内码的高字节,L是指汉字机内码的低字节。
void Display_GTHZ16(unsigned char M,unsigned char L)
    unsigned char i,j;
    unsigned long BaseAdd;
    unsigned char MSB,LSB;
    unsigned long Address;
    unsigned char hzbuf[32];
    unsigned char addr[4];
    MSB=M;
    LSB=L;
BaseAdd=0x00;//以下公式参见GT20L16S1Y规格书的第17页。
if(MSB==0xA9 && LSB>=0xa1)
    Address=(282+(LSB-0XA1))*32+BaseAdd;
    else if(MSB >=0xA1 && MSB <= 0xA3 && LSB >=0xA1)
    Address= ((MSB - 0xA1) * 94 + (LSB - 0xA1))*32+BaseAdd;
    else if(MSB >=0xB0 && MSB <= 0xF7 && LSB >=0xA1)
    Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 1038)*32+ BaseAdd;    ZkReadNByte (Address,hzbuf,32);
for(i=0;i<16;i++)  //以下是显示部分,用的是128X64的STN屏。
    LcdWriteCmd(0XB0+y);
    LcdWriteCmd(0X10|(x+i+4)>>4);
    LcdWriteCmd(0X0F&(x+i+4));
    LcdWriteData(hzbuf[i]);
for(j=0;j<16;j++)
    LcdWriteCmd(0XB0+y+1);
    LcdWriteCmd(0X10|(x+j+4)>>4);
    LcdWriteCmd(0X0F&(x+j+4));
    LcdWriteData(hzbuf[j+16]);
    x=x+16;
读取ASCII编码并显示的函数
void Display_GTAscii16(unsigned char AsciiCode)
    unsigned char i,j;
    unsigned char asciibuf[16];
    BaseAdd=0x3B7C0; //以下公式参见GT20L16S1Y规格书的第18页。
    if(AsciiCode>=20 && AsciiCode <= 0x7E)
    Address=(AsciiCode-0x20) *16+BaseAdd;
    ZkReadNByte (Address,asciibuf,16);
for(i=0;i<8;i++)
    LcdWriteData(asciibuf[i]);
    for(j=0;j<8;j++)
    LcdWriteData(asciibuf[j+8]);
    x=x+8;
在main函数内的实现方法
Void main()
    SystemInit();
    GenitopZkInit();
    Unsigned char *text=”高通科技ABC”;
While(*text!=”\0”)
    If(*text>0x80){
          Display_GTHZ16(*text,*(text++));  //显示汉字
} else {
          Display_GTAscii16(*text);         //显示英文Ascii编码
  Text++;
While(1);
公司介绍:
       深圳高通半导体有限公司成立于2014年11月,其技术及团队传承上海高通半导体有限公司。迄今已来始终致力于中文信息处理技术,坚持发展中文信息民族产业的道路,秉持着用科技传承文化的理念,从1992年DOS时代的汉卡类产品至如今的汉字库芯片产品,持续为行业提供专业的中文信息产品。
       高通公司为国家高新技术企业,软件企业,累积知识产权百余项,专注于中文信息处理集成电路产品,简称字库芯片。其开发产品包含点阵字库芯片、矢量字库芯片、GUI字库芯片、智能字库芯片等,为用户提供各类电子产品中的文字解决方案,使产品在中文信息处理方面的开发更加便捷,效果与品质极大提升。
       逾6000 个客户案例积累,所涵盖领域包括智能穿戴、智能家居、物联网设备、金融设备、智能表、教育、医疗、商用机器等等深圳高通在成本、专业、便捷、标准、品质方面追求极致。在字库产业发展方面取得了骄人的业绩,在行业内的影响力亦日趋提升,整合国内外字库资源,形成全球领先的文字处理信息产业生态链。
       我们深信:汉字作为中华文明的核心之一,有着极其重要的地位。随着世界不断数字化,随着中国不断全球化,中文信息将作为现在与未来的沟通技术,拥有者务必宽广的可能性。无论科技如何发展,我们将致力于发展中文信息产业,秉承用科技传承文化的理念,创造文明智能!
  • 相关推荐
