源创通信SinoV-X516-GOIP GSM/CDMA/WCDMA 网关介绍英文版
  • 产品型号   SinoV-X516
  • 产品描述
    SinoV-X516G series is able to process traditional voice call service and internet data service. SinoV-X16G series adapt new hardware and software structure, which supports up to 16 concurrent calls.
源创通信
产品介绍
Product introduction:
Special Features:
Support G729a/b/e,G723.1,G.711 A/U law, iLBC auto-selecting
            EBO(Ejoin Band with Optimization)
            Proxy Encryption Solution for IP Block
            Support SIM Bank
            VPN(pptp)
            SIM Card Rotating(SinoV-X516G-64)
                    Solution to solve the SIM card blocked by:
                          Accumulated Call Duration
                          Accumulated Connected Calls
                          Accumulated Calls
                          Consecutive Failed Calls
                          Consecutive No-Alert Calls
                          Consecutive No-Answer Calls
                          Consecutive No Carrier Calls
                          Consecutive Short-Duration Calls
            Station intelligent switching
            Port Inter-Calling
            Fake Ringback
            Call Duration Limitation for SIM Card/Single
            Dial Plan/Prefix Inward Translation/Intelligent Routing
            Web Browser: Firefox/Chrome /IE/Opera
Mobile Features:
SMS Send, Receive and Forward(GSM/SIP/HTTP)
            SMS Inbox
            AT Command , USSD
            SMS Format: PDU/TXT
            PIN Code Management
            GSM Polarity Reversal
            Carrier Selection
            Caller ID Hidden(need SIM Card support)
Maintenance and Management:
Multi-language Interface
            USB Serial COM
            Configuration Backup and Restore
            Support HTTP/TFTP Upgrade
            Call statistics: ASR,ACD,PDD
Specifications:
Model
SinoV-X516G-16/64
Number of Channels
16 channels
Frequency
GSM: 850/900/1800/1900MHz
SIP Specification
·SIP/2.0 RFC3261
·Session Timer RFC4028
 ·STUN
Network Protocols
•DHCP/PPPoE/VPN(pptp)
•NTP
•Telnet/HTTP/FTP/TFTP
•Encryption:VOS2000,RC4,XOP.Base64
Telephony Features
Hot-line call ,Dial plan, Speed dial, Phone book, CDR, LCR, White/Black list
Telephony Signaling
 ·DTMF tone dectection/generation
 ·DTMF relay: in-band, RFC 2833 and SIP info
 ·Call forward: unconditional, no answer and busy
 ·N-way conferencing
 ·Caller ID display/generation, Mobile Number Portability
Voice Capability
·Voice codecs:G729a/b/e,G723.1,G.711 A/U law, iLBC
·Echo cancellation
.Silence suppression & detection(VAD, CNG)
·Adaptive jitter buffer
 ·Volume adjustable
  ·IVR customized
Number of Ports
·1 WAN 10/100Base-T ethernet(RJ-45 connector)
·1 LAN 10/100Base-T ethernet(RJ-45 connector)
 ·1 Console(USB)
LEDs
1 Power and 16 groups of card online and running status indicator
Power Supply
100-240VAC, 50 - 60 Hz IN, 12V/5A OUT
Operating Environment
•Operating temperature: 0 - 50ºC
•Operating humidity: 10 – 90%RH
Warranty
12 Months
