源创通信 受电模块简介英文版
  • 产品型号   SinoV-PD-RT9400
  • 产品描述
    The RT9400 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard.
源创通信
产品介绍
Description:
The RT9400 signature and control circuit provides the PoE compatibility signature and
power classification required by the Power Sourcing Equipment (PSE) before applying up
to 15W power to the port. The RT9400  provides a Class 0 signature.
The DC/DC converter operates over a wide input voltage range and provides a regulated
output. The DC/DC converter also has built-in short-circuit output protection.
Features:
·IEEE802.3af compliant
·Input voltage range 36V to 57V
·Integral high efficiency DC/DC converter.
·Low output ripple and noise
·High performance with low price
·Short-circuit protection
·Adjustable Output
·Optional multi-voltage output 3.3V 5V 12V 24V
·Transformer isolation  ,1500V isolation (input to output)
·Easy to use, with a minimum number of external components.
Applications:
·IP Cameras
·Wireless access point
·Security and alarm systems
·VOIP telephone
·Point of sale network terminal equipment
RT9400  Product Selector
Part Number Nominal Output Voltage Maximum Output Power* Marking Package
RT9400-3.3V 3.3V 6.6W 3.3V SIL
RT9400 -5V 5V 10W 5V SIL
RT9400 -12V 12V 12W 12V SIL
RT9400 -24V 24V 12W 24V SIL
*At 25°C with VIN = 48V
Reducing the output voltage, connect R2 between ADJ and +VDC
R2 Value
output voltage
R2 Value
output voltage
 RT9400-3.3V
open
3.3V
0R
2.8V
 RT9400-5V
open
5V
0R
4.4V
 RT9400-12V
open
12V
0R
9.9V
 RT9400-24V
open
24V
30K
18.2V
Increasing the output voltage, connect R1 between ADJ and -VDC
R1 Value
output voltage
R1 Value
output voltage
 RT9400-3.3V
open
3.3V
0R
3.7V
 RT9400-5V
open
5V
0R
5.7V
 RT9400-12V
open
12V
0R
12.8V
 RT9400-24V
open
24V
0R
25.5V
