君正集成电路 T01主板介绍
嵌入式主板
君正集成电路
嵌入式主板
• 专业的视频分析AI协处理器
• 高性能人脸/头肩/人形复合探测
• 成熟的入侵报警/客流统计/人脸抓拍/人脸识别等AI应用方案
• 极低的运行功耗
芯片框图
嵌入式主板
  芯片规格
CPU
XBurst®-1 core 600MHZ/1GHZ
– XBurst® RISC instruction set
– XBurst® SIMD128 instruction set
– XBurst® FPU instruction set supporting both single and double floating point format which are IEEE754 compatible
– XBurst® 9-stage pipeline micro-architecture, the operating frequency is 800MHz
Memory
Integrated DDR
Spirit engine
More than 10 people realtime multi-detection.
Max input resolution 2048x2048 @60fps.
Video input/output
Video input
– DVP Input data format: YUV422, RGB565, RGB555, RAW8, RAW10, RAW12.
– BT656/BT1120
– MIPI CSI2 IN (Ingenic Host Soc Only)
Video output
– MIPI CSI2 OUT (Ingenic Host Soc Only)
Result output
Synchronous serial slave interfaces (SSI_SLV)
– 3 protocols support: Motorola’s SPI, TI’s SSP and National’s Microwire
– Full-duplex, transmit-only or receive-only operation for Motorola’s SPI and TI’s SSP
– Half-duplex, transmit-only or receive-only operation for National’s Microwire
USB 2.0 interface
– Complies with the USB 2.0 standard for high-speed (480 Mbps) functions and with the On-The-Go supplement to the USB 2.0 specification
– Operates either as the function controller of a high- /full-speed USB peripheral or as the host/peripheral in point-to-point or multi-point communications with other USB functions
– 16 Endpoints:
– Dedicate FIFO
– Supports control, interrupt, ISO and bulk transfer
