飞凌嵌入式FETMX8MM-C核心板介绍
CPU:NXP i.MX8M Mini
架构:四核Cortex-A53+M4
主频:1.8GHz
内存:2GB DDR4
ROM:8GB eMMC
系统:Linux4.14.78+QT5.10.1、Android9.0
嵌入式主板
嵌入式主板
嵌入式主板
FETMX8MM-C核心板
FETMX8MM-C 核心板基于NXP 公司的i.MX8M Mini 四核64位处理器设计,主频最高1.8GHz,ARM Cortex-A53架构;2GB DDR4 RAM,支持一个通用型Cortex®-M4 400 MHz内核处理器。可提供多种音频接口,包括I2S、AC97、TDM、PDM和SPDIF。提供多种外设接口,如MIPI-CSI、MIPI-DSI、USB、PCIe、UART、eCSPI、IIC和千兆以太网。
目标应用:
·IP摄像头视频监控                       ·双向视频会议
·可视门铃                                    ·图像分析
·音频处理                                    ·音频广播系统
嵌入式主板
嵌入式主板
嵌入式主板
嵌入式主板
嵌入式主板
嵌入式主板
规格参数
CPU
  • Cortex A53 Core:
    • 4x Cortex-A53 processors
  • • Target frequency of 1.8GHz
  • • Support of 64-bit Armv8-A architecture
  • • Floating Point Unit (FPU) with support of the   VFPv4-D16 architecture
  • • 32 KB L1 Instruction Cache
  • • 32 KB L1 Data Cache
  • • 512 KB unified L2 cache
  • Cortex M4 Core:
    • 1x Cortex-M4 processor
  •   frequency of 400MHz
  • • 256 KB tightly coupled memory (TCM,128 KB TCMU, 128 KB TCML)
RAM
  • • 2GB
  • • DDR4
ROM
  • • 8GB
  • • eMMC Flash
Multimedia Interface
  • LCDIF Display Controller:
  • • Support up to 2 layers of overlay
  • • Support up to 1080p60 display through MIPI DSI
  • MIPI Interface:
  • • 4-lane MIPI CSI interface,operating up to a maximum bit rate of 1.5 Gbps.
  • • 4-lane MIPI DSI interface,operating up to a maximum bit rate of 1.5 Gbps.
  • Audio:
  • • SPDIF input and output, including a new Raw Capture input mode
  •  Five synchronous audio interface (SAI) modules supporting I2S,AC97, TDM,codec/DSP,and DSD interfaces, including one SAI with 8 Tx and 8 Rx lanes, one SAI with 4 Tx and 4 Rx lanes,two SAI with 2 Tx and 2 Rx lanes,and one SAI with 1 Tx and 1Rx lane. Support over 20 channels of audio subject to I/O limitations.
  • • 8-Channel Pulse Density Modulation (PDM) input
GPU
  • 3D GPU Core:
  • • GCNanoUltra
  • • Support OpenGL ES 1.1, 2.0
  • • Support OpenVG 1.1
  • • TrustZone support using a local MMU to manage secure regions
  • 2D GPU Core:
  • • GC320
  • • Support multi-source composition
  • • Support one-pass filter
VPU
  • Decoder:
  • • 1080p60 VP9 Profile 0, 2 (10-bit)
  • • 1080p60 HEVC/H.265 Decoder
  • • 1080p60 AVC/H.264 Baseline, Main, High decoder
  • • 1080p60 VP8
  • Encoder:
  • • 1080p60 AVC/H.264 Encoder
  • • 1080p60 VP8
PCle
  • One PCI Express (PCIe)
  • • Single lane supporting PCIe Gen2
  • • Dual mode operation to function as root complex or   endpoint
  • • Integrated PHY interface
  • • Support L1 low power sub-state
USB
  • Two USB 2.0 OTG controllers with integrated PHY interfaces
SD/SDIO
  • Two Ultra Secure Digital Host Controller (uSDHC) interfaces:
  • • SD/SDIO 3.0 compliance with 200 MHz SDR signaling to support up to 100MB/sec
  • • Support for SDXC (extended capacity)
  • • 1.8 V and 3.3 V operation, but do not support 1.2V operation.
Ethernet
  • One Gigabit Ethernet controller:
  • • support for Energy Efficient Ethernet (EEE)
  • • Ethernet AVB,
  • • IEEE 1588
UART
  • Four Universal Asynchronous Receiver/Transmitter (UART) modules:
  • • 7- or 8-bit data words, 1 or 2 stop bits,   programmable parity (even,odd, or none)
  • • Programmable baud rates up to 4 Mbps.
  • • 32-byte FIFO on Tx and 32 half-word   FIFO on Rx supporting auto-baud
I2C
  • Four I2C modules:
  • I2C provides serial interface for external devices. Data rates of   up to 320 kbps are supported.
eCSPI
  • Three eCSPI modules:
  • Full-duplex enhanced Synchronous Serial Interface, with data rate up   to 52 Mbit/s. Configurable to support Master/Slave modes, four chip selects   to support multiple peripherals.
FlexSPI
  • The FlexSPI module acts s an interface to external serial flash devices.   This module contains the following features:
  • • Flexible sequence engine to support various flash   vendor devices
  • • Single pad/Dual pad/Quad pad mode of operation
  • • Single Data Rate/Double Data Rate mode of operation
  • • Parallel Flash mode
  • • DMA support
  • • Memory mapped read access to connected flash devices
  • • Multi master access with priority and flexible and   configurable buffer for each master
