液晶显示屏模块1602驱动程序源代码
控制/MCU
1799人已加入
液晶显示屏模块1602驱动程序源代码
//lcd1602 drive program for 51 mcu
//designed by Wangchao
//2006-6-14
#i nclude "reg52.h"
//lcd part
#define  LINE1     0
#define  LINE2     1
#define  LINE1_HEAD    0x80
#define  LINE2_HEAD    0xC0
#define  LCD_DELAY_TIME   40
#define  DATA_MODE    0x38
#define  OPEN_SCREEN    0x0C
#define  DISPLAY_ADDRESS   0x80
#define  CLEARSCREEN    LCD_en_command(0x01)
//common part
#define  HIGH   1
#define  LOW    0
#define  TRUE    1
#define  ZERO    0
//change this part at different board
#define  LCDIO     P2
sbit LCD1602_RS=P0^7;   //data command select  1 data  0 command  pin 4
sbit LCD1602_RW=P0^6;   //read write select   1 read   0 write     pin 5
sbit LCD1602_EN=P0^5;   //LCD enable signal             pin 6
void LCD_delay(void);//lcd delay
void LCD_en_command(unsigned char command);//write command
void LCD_en_dat(unsigned char temp);//write data
void LCD_set_xy( unsigned char x, unsigned char y );//set display address
void LCD_write_char( unsigned x,unsigned char y,unsigned char dat);//write lcd a character
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);//write lcd string
void LCD_init(void);//lcd initize
void delay_nms(unsigned int n);//delay
void main(void)
 LCD_init();
 while(TRUE )
   CLEARSCREEN;
  delay_nms(2);
         LCD_write_string(0,LINE1,"Wellcome to DLUT");
         LCD_write_string(0,LINE2,"www.dlut.edu.cn!");
         delay_nms(500);
         CLEARSCREEN;
  delay_nms(2);
         LCD_write_string(0,LINE1,"   lcd test     ");
         LCD_write_string(0,LINE2,"   successful!  ");
         delay_nms(500);
   CLEARSCREEN;
       delay_nms(2);
         LCD_write_string(0,LINE1," I'm WangChao.  ");
         LCD_write_string(0,LINE2,"   Thank You!  ");
       delay_nms(500);
/******************** LCD PART *************************************/
 unsigned char i;
 for(i=LCD_DELAY_TIME;i>ZERO;i--)  //be sure lcd reset
 LCDIO=command;
 LCD1602_RS=LOW;
 LCD1602_RW=LOW;
 LCD1602_EN=LOW;
 LCD_delay();
 LCD1602_EN=HIGH;
void LCD_en_dat(unsigned char dat)
 LCDIO=dat;
 LCD1602_RS=HIGH;
 LCD1602_RW=LOW;
 LCD1602_EN=LOW;
 LCD_delay();
 LCD1602_EN=HIGH;
 unsigned char address;
 if (y == LINE1)
  address = LINE1_HEAD + x;
 else
     address = LINE2_HEAD + x;
 LCD_en_command(address);
 LCD_set_xy( x, y );
 LCD_en_dat(dat);
    LCD_set_xy( X, Y ); //set address
    while (*s)  // write character
     LCDIO=*s;
        LCD_en_dat(*s);
 s ++;
void LCD_init(void)
 CLEARSCREEN;//clear screen
 LCD_en_command(DATA_MODE);//set 8 bit data transmission mode
 LCD_en_command(OPEN_SCREEN);//open display (enable lcd display)
 LCD_en_command(DISPLAY_ADDRESS);//set lcd first display address
/*********************** OTHER PART *********************************/
    unsigned int i=0,j=0;
    for (i=n;i>0;i--)
     for (j=0;j<1140;j++);
