新品快讯
MAX9568 sync separator is easy to use and doesn’t distort the video signal
Relieve your anxiety by using the MAX9568 sync separator to extract timing information from video signals. The MAX9568 can extract video timing information from 525i, 625i, 525p, 625p, 720p, and 1080i formats, without loading or distorting the video signal. Unlike most sync separators, the MAX9568 does not require an oscillator or other external components for operation.
Easy to use
No microprocessor control for setup•
No external timing components • needed
Simple standard output format
Good video quality
• MACROVISION compliant
No loading, so does not distort
• video signal
Low 500ps jiter
