一个X25045的C51读写程序
1.2w人已加入
  * x25045的读写程序 用c51写的 */
  #define CS P2.7 /*单片机p2.7为片选 可以改为你的实际引脚 */
  #define SO P2.6 /*数据输出 */
  #define SK P2.5 /* 时钟 */
  #define SI P2.4 /* 数据输入*/
  /* here is the instrution of x25045*/
  #define WREN 0x06
  #define WRDI 0x04
  #define RDSR 0x05
  #define WRSR 0x01
  #define READ0 0x03
  #define READ1 0x0b
  #define WRITE0 0x02
  #define WRITE1 0x0a
  unsigned char Read8()
  bit bData;
  unsigned char cLoop;
  unsigned char cData;
  for(cLoop=0;cLoop《8;cLoop++)
  SK=1;
  SK=0;
  bData=SO;
  cData《《=1;
  if(bData)
  cData|=0x01;
  return cData;
  void Write8(unsigned char cData)
  if((cData&0x80)==0)
  SI=0;
  else
  SI=1;
  SK=0;
  SK=1;
  cData《《=1;
  unsigned char ReadSR()
  CS=0;
  Write8(RDSR);
  cData=Read8();
  CS=1;
  return cData;
  unsigned char WriteSR(unsigned char cData)
  unsigned char cTemp;
  cTemp=ReadSR();
  if((cTemp&0x01)==1)
  return 0;
  CS=0;
  Write8(WREN);
  CS=1;
  CS=0;
  Write8(WRSR);
  Write8(cData);
  CS=1;
  return 1;
  void Write1B(unsigned char cData,unsigned char cAddress,bit bRegion)
  /* 写入一个字节,cData为写入的数,cAddress为写入地址,bRegion为页 */
  while((ReadSR()&0x01)==1)
  CS=0;
  Write8(WREN);
  CS=1;
  CS=0;
  if(bRegion==0)
  Write8(WRITE0);
  else
  Write8(WRITE1);
  Write8(cAddress);
  Write8(cData);
  SK=0;
  CS=1;
  unsigned char Read1B(unsigned char cAddress,bit bRegion)
  /* 读入一个字节,cAddress为读入地址,bRegion为页 */
  CS=0;
  if(bRegion==0)
  Write8(READ0);
  else
  Write8(READ1);
  Write8(cAddress);
  cData=Read8();
  CS=1;
  return cData;
