飞思卡尔的Kinestis L系列的技术介绍
嵌入式技术
1335人已加入
Freescale Kinetis L Series KL03 MCUs
Freescale did a full market launch of the entire KL03 family, introducing a number of devices and a Freedom board in which customers can get started on their development. The Kinetis KL03 is the ultimate product for portable devices within the IoT space due to its small size and low power consumption (Figure 1). The device also maintains an optimized level of on-chip integration to help customers simplify design and reduce BOM costs and is supported by Freescale’s expansive set of software and tools.
Figure 1: Trends in embedded product design.
The KL03 is in fact smaller than a golf ball dimple (as illustrated by the image in Figure 2), 35% smaller than the nearest competition, but still offers more GPIO than the competition. With a tiny footprint package of 1.6 x 2.0 mm2 WLCSP, the KL03 includes: run power consumption as low as 50 μA/MHz, static power consumption as low as 2.2 μA with 7.5 μs wakeup time for full retention and lowest static mode down to 77 nA in deep sleep, and highly integrated peripherals, including boot ROM and high accurate internal voltage reference.
Figure 2: Kinetis KL03 size comparison.
The KL03 family features include:
A 48 MHz ARM® Cortex®-M0+ core 1.71-3.6 V operation Up to 32 KB flash memory 2 KB RAM 8 KB ROM boot loader for easy flash upgrade Bit manipulation engine for faster, more code-efficient bit-oriented math A high-speed 12-bit analog-to-digital converter Embedded 1.2 V voltage reference for ADC A high-speed analog comparator Low-power UART, SPI, I2C (high speed up to 1 Mb/s) Powerful timers for a broad range of applications, including motor control Operating temperature of -40°C to +105°C QFN (WLCSP is -40°C to +85°C operation) Up to 22 GPIOs, depending on the package
When the customer thinks of Kinetis L, think small size and low power, but also think big portfolio. The Kinetis L series is big and getting bigger. Since introducing this series in September 2012, the portfolio has now grown to more than 200 devices. The LPUART will be provided in more details on each of the different part numbers data sheet. However, the overview table shown in Figure 3 is a good way to see where the KL03 fits in and how to position it with the rest of the devices.
Kinetis
Figure 3: Kinetis L series: MCU families.
As depicted in Figure 4, the Freescale Freedom development platform is a set of software and hardware tools for evaluation and development. It is ideal for rapid prototyping of microcontroller-based applications. The Freescale Freedom KL03Z hardware, FRDM-KL03Z, is a simple, yet sophisticated design featuring a Kinetis L series MCU, built on the ARM Cortex-M0+ core. Processor Expert is a simplified code initialization tool designed to provide 80% of the required firmware from Freescale, allowing designers to focus on the 20% of their own internal code that truly differentiates their products. Solution Advisor is a web-based tool, available on the Freescale website, which allows designers the ability to identify the ideal Kinetis solution by defining the operating characteristics of the device they need, memory configuration, analog, communications and clock peripherals. In addition, it directs them to the associated hardware and software tools and documentation and verifies pin mixing compatibility.
Kinetis
Figure 4: Resources graphic.
In summary, Freescale’s Kinestis L series KL03 is one of the world’s smallest ARM-based MCUs and has excellent performance, is energy-efficient and has many features integrated into a small 1.6 mm x 2.0 mm WLCSP package, enabling miniaturized designs in portable consumer and industrial applications. If the customer is developing a portable application, energy efficiency is going to be a key selling point and with nine low-power modes, this chip has the flexibility to provide power optimization based on the application’s specific requirements. Finally, with software being so much of a customer’s engineering expense today, customers are always looking for ways to reduce their time to market and simplify their software requirements. Using tools, like the Kinetis Design Studio IDE and the Software Development Kit, could save designers months of engineering time and provide them a more seamless way to move around within the ever-expanding Kinetis portfolio, which offers a broad selection of compatible and scalable devices.
飞思卡尔Kinetis L系列MCU KL03
飞思卡尔做了全面的市场推出的整个KL03家族的,引进了一些设备和一自由板,其客户可以在他们的发展开始使用。所述的Kinetis KL03是对的IoT空间内的便携式设备的最终产品,由于其小尺寸和低功耗(图1)。该器件还保持了片上集成的优化水平帮助客户简化设计并降低BOM成本,并支持飞思卡尔的膨胀一套软件和工具。
图1:在嵌入式产品设计趋势。
该KL03实际上比高尔夫球凹坑(如在图2中所示的图像),比最接近的竞争小35%以下,但仍提供了比竞争更多的GPIO。随着1.6×2.0平方毫米WLCSP小尺寸封装,KL03包括:运行功耗低至50μA/ MHz的,静态功耗低至2.2μA7.5微秒的唤醒时间充分保留和最低的静态模式下为77娜深度睡眠,并高度集成的外设,包括引导ROM和高精确的内部电压基准。
Kinetis
图2:的Kinetis KL03大小比较。
该KL03系列的特性包括:
•48 MHz的ARM®Cortex®-M0 +内核
•1.71-3.6 V工作
•高达32 KB的Flash存储器
•2 KB RAM
方便的闪存升级•8 KB的ROM引导装载程序
•位操作引擎更快,更多的代码效率面向比特的数学
•一个高速12位模拟数字转换器
•用于嵌入式ADC 1.2 V基准电压
•一个高速模拟比较器
•低功耗UART,SPI,I2C(高速可达1 Mb / s的)
•强大的定时器,用于广泛的应用,包括电机控制
•工作在-40°C的温度至+ 105°C QFN封装(WLCSP为-40°C至+ 85°C的操作)
•多达22个GPIO,取决于包
当客户想到的Kinetis L,认为小尺寸和低功耗,而且还觉得大组合。该的Kinetis L系列是大而变得越来越大。自从推出这个系列的2012年9月,投资组合,现在已经发展到超过200台设备。该LPUART将在每个不同的部件号数据表的更多细节来提供。然而,在图3所示的概述表上看到KL03适合于和如何将其与设备的其余部分的位置的良好途径。
图3:的Kinetis L系列:MCU系列。
如描绘在图4中,飞思卡尔自由开发平台是一组用于评估和开发的软件和硬件工具。它是非常适合基于微控制器的应用的快速原型设计。飞思卡尔自由KL03Z硬件,FRDM-KL03Z,是一种简单,但复杂的设计,具有的Kinetis L系列MCU,内置于ARM的Cortex-M0 +内核。处理器专家是一个简化的代码初始化工具,旨在提供80%来自飞思卡尔所需的固件,使设计人员能够专注于自己的内部代码的20%,真正区分他们的产品。解决方案顾问是一个基于Web的工具,可在飞思卡尔的网站,它允许设计人员通过定义自己所需要的设备,内存配置,模拟,通信和时钟外设的工作特性来确定理想的Kinetis解决方案的能力上。此外,它指示它们相关的硬件和软件工具和文档,并验证销混合相容性。
图4:资源的图形。
总之,飞思卡尔的Kinestis L系列KL03是世界上最小的基于ARM的微控制器之一,具有优异的性能,是节能的,并具有许多功能集成到一个小型1.6毫米×2.0毫米WLCSP封装,在便携式消费实现小型化设计和工业应用。如果客户正在开发一种便携式的应用程序,能效将是一个关键的卖点,并与九个低功耗模式,该芯片具有很大的灵活性,以提供基于应用程序的具体要求来优化功耗。最后,软件这么多的今天客户的工程费用,客户一直在寻找方法,以减少他们的上市时间并简化其软件需求。使用的工具,像Kinetis产品设计工作室IDE和软件开发工具包,可以节省工程时间设计个月,并为他们提供更加无缝的方式来不断扩大的Kinetis组合中走动,它提供了一个广阔的选择兼容的,可扩展的设备。
