CWDM MUX/DEMUX
今日头条
1095人已加入
CWDM Mux/Demux modules provides the most robust and low-cost  bandwidth upgrade for your current fiber optic communication networks. The core of CWDM Module application is the passive MUX/DEMUX unit. CWDM MUX/DEMUX are available in 4, 5, 8, 9, 16, 18 channel configurations. Each CWDM module supports ESCON, ATM, Fibre Channel, and Gigabit Ethernet over each port.. Available in  ABS box package, LGX pakcage and 19” 1U rackmount. Optional wide band port for existing 1310nm or 1550nm port is available to multiplex with these CWDM Channels. Our CWDM Mux/Demux modules provide low insertion loss, high channel isolation, wide pass band, low temperature sensitivity and epoxy free optical path.
2 channel CWDM Mux/Demux
4 channel CWDM Mux/Demux
5 channel CWDM Mux/Demux
8 channel CWDM Mux/Demux
9 channel CWDM Mux/Demux
16 channel CWDM Mux/Demux
18 channel CWDM Mux/Demux
