三款MAX761典型应用电路图详解
应用电子电路
804人已加入
  MAX761典型应用电路图(一)
  电路的输出电压Vo取决于③脚的接法,若③脚接地,为选择IC的内反馈控制,输出电压为12V;当③脚接R1和R2时,则选择为外反馈控制,此时输出电压由下式确定:Vo=1.5(R1+R2)/R2。
  调节R1和R2的电阻值可以得到不同的输出电压。
  MAX761
  MAX761典型应用电路图(二)
  MAX761
  MAX761典型应用电路图(三)
  图所示为由高效、低功耗升压直流变换器MAX761和几只外围元件构成的5V→12V升压电源。其特点是:变换效率为86%;静态电流为110μA;具有低电池电压检测功能,图中R3、R4是电池电压检测分压电阻,一般可按经验公式:R4=R3(VTPIP/1.5-1)来计算,VTPIP为检测触发电压。
  MAX761
评论(0)
发评论
gztoppower 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%252C%2B%25C3%25E5%25B5%25E9%25D3%25F1%25BA%25CD%25B9%25FA%25BC%25CA%25B6%25B7%25C5%25A3B2024.cN%252C%25B6%25AB%25DD%25B8%25B9%25E3%25B2%25A5_3s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%25CD%25F8%25D5%25BE%252C%2B%25C3%25E5%25B5%25E9%25BD%25F0%25B6%25A6%25D3%25E9%25C0%25D6B2024.cN_47s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%25CD%25F8%25D5%25BE%252C%2B%25C3%25E5%25B5%25E9%25B0%25EB%25C9%25BD%25BC%25AF%25CD%25C5%25BC%25AF%25CD%25C5B2024.cN_71s.htm http://house.china.com.cn/sousou/%25C1%25AA%25CF%25B5%25B7%25BD%25CA%25BD%252C%2B%25B9%25FB%25B8%25D2%25D3%25F1%25BA%25CD%25BC%25AF%25CD%25C5B2024.cN%252C%25D0%25C2%25CE%25C5%25D6%25D0%25D0%25C4_2s.htm http://house.china.com.cn/sousou/%25C6%25F3%25D2%25B5%252C%2B%25C3%25E5%25B1%25B1%25D3%25C0%25B2%25FDB2024.cN%252C%25C8%25AA%25D6%25DD%25B7%25D6%25D5%25BE_2s.htm 收起回复
