TL28L92--3.3V/5V 双路通用异步接收器/发送器
新品快讯
29人已加入
产品信息
特性
SC28L92 Pin Compatible
3.3 V to 5.0 V, –40°C to 85°C and 68xxx or 80xxx Bus Interface
Dual Full-Duplex Independent Asynchronous Receiver/Transmitters
16 Character FIFOs for Each Receiver and Transmitter
Pin Programming Selects 68xxx or 80xxx Bus Interface
Programmable Data Format
5 Data to 8 Data Bits Plus Parity
Odd, Even, No Parity or Force Parity
1 Stop, 1.5 Stop or 2 Stop Bits Programmable in 1/16-Bit Increments
16-Bit Programmable Counter/Timer
Programmable Baud Rate for Each Receiver and Transmitter Selectable From:
28 Fixed Rates: 50 Bd to 230.4 kBd
Other Baud Rates to 1 MHz at 16×
Programmable User-Defined Rates Derived From a Programmable Counter/Timer
External 1× or 16× Clock
Parity, Framing, and Overrun Error Detection
False Start Bit Detection
Line Break Detection and Generation
Programmable Channel Mode
Normal (Full-Duplex)
Automatic Echo
Local Loopback
Remote Loopback
Multi-Drop Mode (Also Called Wake-Up or 9-Bit)
Multi-Function 7-Bit Input Port
(Includes IACKN)
Can Serve as Clock or Control Inputs
Change of State Detection on Four Inputs Inputs Have Typically > 100 k Pullup Resistors
Change of State Detectors for Modem Control
Multi-Function 8-Bit Output Port
Individual Bit Set/Reset Capability
Outputs Can Be Programmed to Be Status/Interrupt Signals
FIFO Status for DMA Interface
Versatile Interrupt System
Single Interrupt Output With Eight Maskable Interrupting Conditions
Output Port Can be Configured to Provide a Total of up to Five Separate Interrupt Outputs That May be Wire ORed
Each FIFO Can be Programmed for Four Different Interrupt Levels
Watchdog Timer for Each Receiver
Maximum Data Transfer Rates: 1× – 1 Mbit/s, 16× – 1 Mbit/s
Automatic Wake-Up Mode for Multi-Drop Applications
Start-End Break Interrupt/Status
Detects Break Which Originates in the Middle of a Character
On-Chip Crystal Oscillator
Powerdown Mode
Receiver Time-Out Mode
Single 3.3 V or 5 V Power Supply
Powers up to Emulate SC26C92
Meets or Exceeds JEDEC 14C ESD Requirements
说明
The TL28L92 is a pin and function replacement for the SC26C92 operating at 3.3 V or 5 V supply with added features and deeper FIFOs. Its configuration on power-up is that of the SC26C92. Its differences from the SC26C92 are: 16 character receiver, 16 character transmit FIFOs, watchdog timer for each receiver, mode register 0 is added, extended baud rate and overall faster speeds, programmable receiver and transmitter interrupts.
Pin programming will allow the device to operate with either the Motorola or Intel bus interface. The bit 3 of the MR0A register allows the device to operate in an 8 byte FIFO mode if strict compliance with the SC26C92 FIFO structure is required.
The Texas Instruments TL28L92 Dual Universal Asynchronous Receiver/Transmitter (DUART) is a single-chip CMOS-LSI communications device that provides two full-duplex asynchronous receiver/transmitter channels in a single package. It interfaces directly with microprocessors and may be used in a polled or interrupt driven system with modem and DMA interface.
The operating mode and data format of each channel can be programmed independently. Additionally, each receiver and transmitter can select its operating speed as one of 28 fixed baud rates; a 16× clock derived from a programmable counter/timer, or an external 1× or 16× clock. The baud rate generator and counter/timer can operate directly from a crystal or from external clock inputs. The ability to independently program the operating speed of the receiver and transmitter make the DUART particularly attractive for dual-speed channel applications such as clustered terminal systems.
Each receiver and transmitter is buffered by 8 or 16 character FIFOs to minimize the potential of receiver overrun, transmitter underrun and to reduce interrupt overhead in interrupt driven systems. In addition, a flow control capability is provided via RTS/CTS signaling to disable a remote transmitter when the receiver buffer is full. Also provided on the TL28L92 are a multipurpose 7-bit input port and a multipurpose 8-bit output port. These can be used as general purpose I/O ports or can be assigned specific functions (such as clock inputs or status/interrupt outputs) under program control.
The TL28L92 is available now in 44-pin QFP (FR), and will be available 2Q09 in 48-pin QFN (RGZ).
