液晶电视
Supply voltage minimum |
Supply voltage maximum |
Maximum segment current |
12mA (2.7V = V+ = 3.0V) | ||
Maximum number of seven-segment digits |
Types of seven-segment digits that can be used |
Maximum number of discrete LEDs |
Can drive 8x8 matrix digits? |
Interface type |
Interface speed maximum |
Interface Dout pin for cascading devices? |
Interface logic input thresholds |
Through-hole package |
Surface-mount package |
Slew-limited LED drive outputs? |
Multiplex clock generation |
Multiplex timing period per digit |
Automatic segment blinking? |
LED intensity levels |
Character decoding |
HEX CODE
No-Op |
No-Op |
Digit 0 |
Digit 1 |
Digit 2 |
Digit 3 |
Digit 4 |
Digit 5 |
Digit 6 |
Digit 7 |
Decode Mode |
Conflicts with MAX7219/MAX7221 Digit 0 |
Intensity |
Conflicts with MAX7219/MAX7221 Digit 1 |
Scan Limit |
Conflicts with MAX7219/MAX7221 Digit 2 |
Configuration |
Conflicts with MAX7219/MAX7221 Digit 3 |
Display Test |
Conflicts with MAX7219/MAX7221 Digit 6 |
Decode Mode |
Intensity |
Scan Limit |
Configuration |
Display Test |
Digit 0 plane P0 only (plane 1 unchanged) |
Digit 1 plane P0 only (plane 1 unchanged) |
Digit 2 plane P0 only (plane 1 unchanged) |
Digit 3 plane P0 only (plane 1 unchanged) |
Digit 4 plane P0 only (plane 1 unchanged) |
Digit 5 plane P0 only (plane 1 unchanged) |
Digit 6 plane P0 only (plane 1 unchanged) |
Digit 7 plane P0 only (plane 1 unchanged) |
Digit 0 plane P1 only (plane 0 unchanged) |
Digit 1 plane P1 only (plane 0 unchanged) |
Digit 2 plane P1 only (plane 0 unchanged) |
Digit 3 plane P1 only (plane 0 unchanged) |
Digit 4 plane P1 only (plane 0 unchanged) |
Digit 5 plane P1 only (plane 0 unchanged) |
Digit 6 plane P1 only (plane 0 unchanged) |
Digit 7 plane P1 only (plane 0 unchanged) |
Digit 0 plane P0 and plane P1 (with same data) |
Digit 1 plane P0 and plane P1 (with same data) |
Digit 2 plane P0 and plane P1 (with same data) |
Digit 3 plane P0 and plane P1 (with same data) |
Digit 4 plane P0 and plane P1 (with same data) |
Digit 5 plane P0 and plane P1 (with same data) |
Digit 6 plane P0 and plane P1 (with same data) |
Digit 7 plane P0 and plane P1 (with same data) |
