如何将单片机操作系统RTX51移植到单片机实验平台
1.2w人已加入
  RTX51原理注释:由于英文原文会比较好,所以我没有翻译过来(不过也写了部分的翻译),直接提取出来一些英文,总结在一起。
  1. 进程管理( Task Management )
  1) 进程类型( Classes of Tasks )
  RTX-51 recognizes two classes of tasks:
  1. Fast tasks
  n Contain especially short responses and interrupt disable times.
  n Contain a separate register bank and a separate stack area (register banks 1, 2 and 3)。(Figure 1)
  n Contain the highest task priority (priority 3) and can therefore interrupt standard tasks.
  n All contain the same priority and can therefore not be mutually interrupted.
  n Can be interrupted by c51 interrupt functions.
  n A maximum of three fast tasks can be active in the system.
  2. Standard tasks
  n Require somewhat more time for the task switching compared to fast tasks.
  n Share a common register bank and a common stack area (register bank 0)。
  n The current contents of registers and stack are stored in the external (XDATA) memory during a task change.
  n Can be interrupted by fast tasks.
  n Can interrupt themselves mutually.
  n Can be interrupt by c51 interrupt functions.
  n A maximum 16 standard tasks can be active in the system.
  内存
  每一个标准进程都包含一个设备上下文在扩展内存(XDATA)中。在标准进程执行进程切换的时候,会把它自己的Register和Stack存储到对应的设备上下文中(在扩展内存中的一个区域)。之后,Register和Statck又从设备上下文中重新载入,继续执行。(交换技术)
  相比而言,快速进程则不用这么麻烦,因为它们有各自独立的Register和Stack,所以只要激活对应的Register(修改PSW)和指向Stack的指针(Mov SP,#XX)即可。
  2) 进程状态(Task states)
  RTX-51 recognizes four task states:
  1. READY All tasks which can run are READY. One of these tasks is the RUNNING (ACTIVE)task.
  2. RUNNING (ACTIVE) Task which is currently being executed bythe processor. Only one task (maximum) can be in this state at a time.
  3. BLOCKED (WAITING) Task waits for an event.
  4. SLEEPING All tasks which were not started or which have terminated themselves are in this state.
  内存
  3) 进程调度(Task switch)
  The RTX-51 system section which the processors assigns to the individual tasks is referred to as the scheduler (also dispatcher)。
  The RTX_51 scheduler works according to the following rules:
  1. The task with the highest priority of all tasks in the READY state is executed.
  2. If several tasks of the same priority are in the READY state,the task that has been ready the longest will be the next to execute.
  3. Task switchings are only executed if the first rule would have been otherwise violated (exception: round-robin scheduling)。
  Time-slice task change (round-robin scheduling) are executed if the following conditions are satisfied:
  1. Round-robin scheduling must be enabled (see configuration)。
  2. The RUNNING task has the priority of 0 and is currently not executing a floating-point operation (see section “Floating-Point Operations”, page 28)。
  3. At least one task with the priority zero must be in the READY state.
  4. The last task change must have occurred after the selected system time interval (see system function “os_set_slice”)。 The system time interval can be changed dynamically during program execution.
  4) 进程通信和同步(Task Communication and Synchronisation)
  There three two mechanisms:
  1. Signal
  Signals represent the simplest and fastest form of task communication. These can always be used when a pure task synchronisation is required without data exchange.
  Each active task contains its own signal flag with which the following operations can be executed:
  l Wait for a signal
  l Send signal
  l Clear signal
  The task number (see section section “Task Declaration”) of the receiver task is used for identifying the signals for the individual operations.
  2. Message(via MailBoxes(FIFO))
  n By means of the mailbox concept, messages can be exchanged free of conflicts between the individual tasks.
  n RTX-51 provides a fixed number of eight mailboxes. Messages can be exchanged in words (2 bytes) via these mailboxes. In this case, a message can represent the actual data to be transferred or the identification of a data buffer(defined by the user)。 In comparison to the signals, mailboxes are not assigned a fixed task, but can be freely used by all tasks and interrupt functions. These are identified with a mailbox number.
  Mailboxes allow the following operations:
  l Send a message
  l Read a message
  Each mailbox is internally consists of three wait lists.(Figure 2)
  内存
  Figure 2
  1. Message list
  List of the messages written in the mailbox. These comprise a maximum of eight messages.
  2. Write wait list
  Wait list for tasks which want to write a message in the message list of the mailbox (maximum 16 tasks)。
  3. Read wait list
  Wait list for tasks which want to read a message from the message list of the mailbox (maximum 16 tasks)。
  3. Semaphore
  n By means of the semaphore concept, resources can be shared free of conflicts between the individual tasks.
  n A semaphore contains a token that your code acquires to continue execution. If the resource is already in use, the requesting task is blocked until the token is returned to the semaphore by its current owner.
  n There are two types of semaphores: binary semaphores and counting semaphores. As its name implies, a binary semaphore can only take two values: zero or one (token is in or out)。 A counting semaphore, however, allows values between zero and 65535.
  RTX-51 provides a fixed number of eight semaphores of the binary type.
  Semaphores allow the following operations:
  l Wait for token
  l Return (send) token
  2. 中断管理
  RTX-51 performs task synchronisation for external events by means of the interrupt system.
  Two types of interrupt processing are basically supported in this case:
  1. 单片机c语言 Interrupt Functions (Interrupt are processed by c51 interrupt funcions)
  l Very sudden, periodically occurring interrupts without large coupling with the rest of the system (only infrequent communication with RTX-51 tasks, etc.)。
  l Very important interrupts which must be served immediately independent of the current system state.
  2. Task Interrupts(Interrupt are processed by fast or standard tasks of RTX-51
  l Fast Task Interrupts
  Important or periodic interrupts which must heavily communicate with the rest of the system when they occur.
  l Standard Task Interrupts
  Only seldom occurring interrupts which must not be served immediately.
  RTX-51 shows considerable different response times for fast and standard tasks.
  u The INTERRUPT ENABLE registers of the 8051 are managed by RTX-51 and must not be directly manipulated by the user!
  u The Interrupt Priority registers of the 8051 (not to be confused with the softwaretask priorities) are not influenced by RTX-51.
  3. 动态内存管理
  RTX-51 uses a simple and effective algorithm, which functions with memory blocks of a fixed size. All memory blocks of the same size are managed in a socalled memory pool. A maximum of 16 memory pools each a different block size can be defined. A maximum of 255 memory blocks can be managed in each pool.
  n Generate Memory Pool
  The application can generate a maximum of 16 memory pools with various block sizes. The application must provide an XDATA area for this purpose. The pool is stored and managed by RTX-51 in this area (see system function “os_create_pool”)。
  n Request Memory Block from Pool
  As soon as a pool has been generated, the application can request memory
  blocks. The individual pools are identified by their block size in this case.
  If an additional block is still free in the pool, RTX-51 supplies the start address
  of this block to the application. If no block is free, a null pointer is returned (see
  system function “os_get_block”)。
  n Return Memory Block to Pool
  If the application no longer needs a requested memory block, it can be returned
  to the pool for additional use (see system function “os_free_block”)。
  4. 时间管理
  RTX-51 maintains an internal time counter, which measures the relative time passed since system start. The physical source of this time base is a hardware timer that generates an interrupt periodically. The time passed between these interrupts is called a system time slice or a system tick.
  This time base is used to support time dependent services, such as pause or timeout on a task wait.
  Three time-related functions are supported:
  n Set system time slice
  The period between the interrupts of the system timer sets the “granularity” of the time base. The length of this period, also called a time slice, can be set by the application in a wide range (see system function “os_set_slice”)。
  n Delay a task
  A task may be delayed for a selectable number of time slices. Upon calling this system function the task will be blocked (sleep) until the specified number of system ticks has passed (see system function “os_wait”)。
  n Cyclic task activation
  For many real-time applications it is a requirement to do something on a regular basis. A periodic task activation can be achieved by the RTX interval wait function (see system function “os_wait”)。 The amount of time spent between two execution periods of the same task is controlled, using os_wait, and is measured in number of system ticks and may be set by the application.
  5. RTX(FULL)函数纵览(Functions Overview)
  Initialize and Start the System:
  os_start_system (task_number)
  Task Management:
  os_create_task (task_number)
  os_delete_task (task_number)
  os_ running_task_id ()
  Interrupt Management:
  os_attach_interrupt (interrupt)
  os_detach_interrupt (interrupt)
  os_enable_isr (interrupt)
  os_disable_isr (interrupt)
  os_wait (event_selector, timeout, 0)
  oi_set_int_masks (ien0, ien1, ien2)
  oi_reset_int_masks (ien0, ien1, ien2)
  Signal Functions:
  os_send_signal (task_number)
  os_clear_signal (task_number)
  isr_send_signal (task_number)
  Message Functions:
  os_send_message (mailbox, message, timeout)
  os_wait (event_selector, timeout, *message)
  isr_send_message (mailbox, message)
  isr_recv_message (mailbox, *message)
  Semaphore Functions:
  os_send_token (semaphore)
  Dynamic Memory Management:
  os_create_pool (block_size, *memory, mem_size)
  os_get_block (block_size)
  os_free_block (block_size, *block)
  Functions with the System Clock:
  os_set_slice (timeslice)
  Debug Functions:
  os_check_tasks (*table)
  os_check_task (task_number, *table)
  os_check_mailboxes (*table)
  os_check_mailbox (mailbox, *table)
  os_check_semaphores (*table)
  os_check_semaphore (semaphore, *table)
  os_check_pool (block_size, *table)
  三.RTX51移植
  本试验是用的RTX的Tiny版本。也就是说没有优先级之分,没有邮箱机制,没有动态内存的管理。移植它很简单,就是配置一下它带的配置文件,然后和写好的程序一起编译连接,连接的时候加一个rtxtny参数,意思是说当我连接的时候,我把RTXtiny的库文件连接上,也就等于是程序和操作系统编译在一起了。该配置文件能在安装目的rtxtiny2底下找到。文件名称为Conf_tny.A51,例如,在我的电脑中,路径为:D:\Keil\单片机c语言\RtxTiny2\SourceCode\ Conf_tny.A51。如下图所示:
  内存
  由于试验箱里面的芯片是AT89C51,所以要配置Conf_tny.A51的RAMTOP EQU 07F,目的是说配置内部RAM为128字节。
  四.源程序代码:
  源程序代码如下,说明请看代码里面的注释。
  ** RTX-51的移植
  ** 移植到AT89S52
  ** 此程序是循环花样显示LED灯
  ** 有三个显示样式,分别对应下面的三个进程
  ** 下面的算法中用到了“时间到空间”的转换,使得算法简化不少
  ** 此程序我已在最小系统板上试验通过。
  #include 《reg51.h》
  #include 《rtx51tny.h》
  const unsigned char table[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80
  ,0x40,0x20,0x10,0x08,0x04,0x02,0x01,0xFF,0x00};
  /*时间到空间的转换,如果table是:
  const unsigned char table[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  则算法和代码会多出一倍来。table数组虽然增加了一倍,算法也随之减少了一半,
  好处当然不止在这里体现,下面的进程2也减少了一半*/
  //进程0 左-》右-》左
  void LED0 (void) _task_ 0
  int i;
  os_create_task(1);//创建进程1
  os_create_task(2);//创建进程2
  while(1)
  for (i = 0; i 《 15; i++)
  P1 = table[i];
  os_wait(K_TMO,30,0);//等待30*10000微妙 = 0.3秒
  os_send_signal(1); //发送Signal信号,激活进程1
  os_wait(K_SIG,0,0); //等待信号
  //进程1 全亮-》全灭-》全亮
  void LED1 (void) _task_ 1
  int i;
  while(1)
  os_wait(K_SIG,0,0);
  for (i = 0; i 《 3; i++)
  P1 = table[15]; //全亮
  P1 = table[16]; //全灭
  os_send_signal(2);
  //进程2 两边-》中间中间-》两边
  void LED2 (void) _task_ 2
  int i;
  while(1)
  os_wait(K_SIG,0,0);
  for (i = 0; i 《 8; i++)
  P1 = table[i] | table[i+7]; //由于table长度多一倍,省去了一个循环,而且算法也简化了。
  os_send_signal(0);
  五.总结:
  本试验用的RTX 的Tiny 版本。许多比较高级的功能没有去实现。目的主要是理解RTX的原理,然后移植它到某个单片机上面,编写个小程序来测试一下。通过阅读RTX附带的英文文档,我对此操作系统有了深刻的认识,感到此操作系统有很多优点,也有很多不足的地方。比如支持的任务较少,不过由于是单片机,“承受”能力也有限,也能理解。总的来说,对于单片机来说是个不错的操作系统。
