AT89C2051内部比较器应用例子
嵌入式设计应用
129人已加入
AT89C2051内部比较器应用例子
This program implements a simple two-digit voltmeter, utilizing an
  ; AT89Cx051 microcontroller, two resistors, a capacitor and two HP5082-7300
  ; decimal LED displays. The code is compatible with both the AT89C1051 and
  ; AT89C2051 when operating with a 12 MHz clock. Code modifications may be
  ; required for operation at a different clock rate.
  ; The voltmeter application demonstrates the RC analog-to-digital conversion
  ; method. The microcontroller uses an output pin, which swings from ground to
  ; Vcc, to alternately charge and discharge the capacitor through a resistor.
  ; Utilizing the internal comparator, the microcontroller measures the time
  ; required for the voltage on the capacitor to match the unknown voltage and
  ; uses the result as an index into a table. The table contains display values
  ; corresponding to the capacitor voltage. Each display value is encoded in
  ; one byte as two BCD digits, which are displayed as volts and tenths of a
  ; volt on the two decimal displays. There is no software hysteresis, so the
  ; display may oscillate at a transition voltage.
  ; The conversion routine, ADC, is general purpose, returning the entry in
  ; the table which corresponds to the measured time. The table contents may
  ; be modified to any data format required by an application.
The NOP instructions in the conversion routine are used to delay the first
  ; sample in the charge and discharge portions of the measurement cycle.
  ; The amount of delay has an effect on measurement accuracy, and the number
  ; of NOPs may be adjusted (slightly) for best results.
  ; SCOUNT is defined as the minimum number of samples which must be taken to
  ; guarantee that the voltage on the capacitor has reached Vcc/2. TCHARGE and
  ; TDISCHARGE are defined as the minimum time required for the voltage on the
  ; capacitor to approach within 1/2 delta V of Vcc and ground, respectively.
  ; The minimum conversion time is approximately TCHARGE + TDISCHARGE, or
  ; six milliseconds. The maximum conversion time is approximately TCHARGE +
  ; TDISCHARGE + 2 * (5 microseconds * SCOUNT), or seven milliseconds.
  ; For additional information refer to the application note.
  SCOUNT    EQU  79    ; minimum samples to reach Vcc/2
  TCHARGE    EQU  3    ; cap charge time, in milliseconds
  TDISCHARGE  EQU  3    ; cap discharge time, in milliseconds
  DSEG AT 0020H
  ORG  0020H    ; stack origin
  stack:    DS  0020H    ; stack depth
  CSEG
  ORG  0000H    ; power on/reset vector
  jmp  on_reset
  ORG  0003H    ; external interrupt 0 vector
  reti      ; undefined
  ORG  000BH    ; timer 0 overflow vector
  reti      ; undefined
  ORG  0013H    ; external interrupt 1 vector
  reti      ; undefined
  ORG  001BH    ; timer 1 overflow vector
  reti      ; undefined
  ORG  0023H    ; serial I/O interrupt vector
  reti      ; undefined
  ORG  0040H    ; begin constant data space
  $INCLUDE(vtable.asm)      ; get lookup table
  ORG  00E0H    ; begin code space
  USING  0    ; register bank zero
  on_reset:
  mov  sp, #(stack-1)  ; initialize stack pointer
  mov  IE, #0    ; deactivate all interrupts
  mov  p1, #0    ; write zeros to displays
  mov  a, #0ffh  ; deactivate output ports
  mov  p1, a    ;
  mov  p3, a    ;
  clr  p3.7    ; discharge capacitor
  mov  a, #TDISCHARGE  ; wait
  call  delay_ms  ;
  loop:
  call  adc    ; convert
  call  vshow    ; display voltage
  sjmp  loop    ; again
  ADC:
  ; Convert analog-to-digital.
; Triggers capacitor charge/discharge and samples the comparator
  ; output at regular intervals until the comparator changes state.
  ; The sample interval is five microseconds with a 12 MHz clock.
  ; A maximum of SCOUNT samples are taken during the charge portion
  ; of the cycle and SCOUNT samples during the discharge portion of
  ; the cycle. The number of samples is used as an index into a table
  ; containing voltage equivalents. The number of table entries is
  ; twice SCOUNT. If the comparator does not switch, the last table
  ; entry is returned. Assumes that the capacitor is fully discharged
  ; on entry, and discharges the capacitor before return.
  ; The table entry is returned in A. Nothing is saved.
  ; Charge capacitor.
  mov  a, #0    ; initialize loop count
  setb  p3.7    ; begin charging    1 uS
  nop      ; padding      1 uS
  nop      ;        1 uS
  ad1:
  jb  p3.6, ad4  ; jump if comp output high  2 uS
  inc  a    ; increment count    1 uS
  cjne  a, #SCOUNT, ad1  ; loop until timeout    2 uS
  ; Timeout.
  ; Be sure capacitor is fully charged.
  mov  a, #TCHARGE  ; wait
  call  delay_ms  ;
  ; Discharge capacitor.
  clr  p3.7    ; begin discharging    1 uS
  nop      ; padding      1 uS
  nop      ;        1 uS
  ad2:
  jnb  p3.6, ad3  ; jump if comp output low  2 uS
  cjne  a, #SCOUNT, ad2  ; loop until timeout    2 uS
  ; Timeout.
  dec  a    ; last count
  ad3:
  add  a, #SCOUNT  ; use top half of table
  ; Fetch table entry.
  ad4:
  mov  dptr, #VoltTable  ; pointer to base of table
  movc  a, @a+dptr    ; get voltage data
  push  acc      ; save data temporarily
  ; Be sure capacitor is fully discharged.
  call  delay_ms  ;
  pop  acc
  ret
  vshow:
; Display two BCD digits on a pair of HP5082-7300 displays.
  ; The four data lines to each display share P1.7:1.4. The units
  ; display is selected by a low on P1.3 and the tenths display by a
  ; low on P1.2. The units display is wired to light the decimal point.
  ; On entry, expects two packed BCD digits in A. Returns nothing.
  ; All registers preserved, including flags.
  push  psw
  push  acc
  push  acc    ; save digits
  orl  a, #00001111b  ; set unused bits
  mov  p1, a    ; write units digit
  clr  p1.3    ; strobe data into display
  setb  p1.3    ;
  pop  acc    ; restore digits
  swap  a    ; move low digit into high nybble
  mov  p1, a    ; write tenths digit
  clr  p1.2    ; strobe data into display
  setb  p1.2    ;
  pop  acc
  pop  psw
  ret
  delay_ms:
  ; Delay for approximately one millisecond times the value in A.
  push  psw
  push  acc
  push  b
  mov  b, #0
  ddm:
  djnz  b, $    ; 512 uS @ 12 MHz
  djnz  acc, ddm
  pop  b
  pop  acc
  pop  psw
  ret
  END
AT89C2051
