基于MIKROE-3263传感器-转换器信号调节的参考设计
消耗积分:0 | 格式:pdf | 大小:55.29KB | 2021-01-15
分享资料个
说明
  • MIKROE-3263, Temp&Hum 8 Click Board is based on a sensor from the popular SHT family, designed to measure temperature and humidity. This sensor family has already become an industry standard, providing proven reliability and stability while requiring a minimum number of components, making the development of applications cheaper and faster. The sensor used on this click is labeled as SHT21, which features a high degree of measurement linearity. Featuring high accuracy, good linearity, proven reliability, and long-term stability, you can use this sensor can for many different applications. Some of them include weather stations, various environmental data collection applications, IoT based applications, and all applications that require a reliable thermal and humidity readings over longer periods of time
主要特色
  • 输入信号幅度
    3.3 V
评论(0)
发评论
下载排行榜
