VICOR电源HAM™AC谐波衰减模块特性与优势
今日头条
1100人已加入
VICOR电源HAM模块是一个全波整流器,充分利用特有的高频率零电流电源开关(ZCS)升压转换器,具备多达675W的工作功率,封装规格仅有4.6“x2.4”x0.5“(116.9x61x12.7mm)。高升压HAM和我们的V375,VI-26x或VI-J6xDC-DC转换器的组成,为高度密集,开关电源提供了开关电源传送基本功能,以大于0.99的功率因素满足了EN61000-3-2的谐波电流的含量需求。
特性与优势
0.99功率因素
EN61000-3-2谐波的含量
通用输入:85-264Vac
过载保护
深圳市立维创展科技是VICOR电源模块的代理经销商,主要提供DC-DC、AC-DC电源模块,隔离、非隔离电源模块转换器等,立维创展致力为客户提供高品质、高质量、价格公正的微波元器件产品,欢迎咨询.
详情了解VICOR电源模块请点击:http://www.leadwaytk.com/public/brand/18.html
或联系我们的销售工程师:0755-83642657   QQ: 2295048674
Part Number 产品类型 产品等级 输出功率 (W) 符合RoHS
VI-HAMD-ML Driver HAM for use with the BAMD –55°C to +85°C 675 No
VI-HAMD-IL Driver HAM for use with the BAMD –40°C to +85°C 675 No
VI-HAMD-EL Driver HAM for use with the BAMD –10°C to +85°C 675 No
VI-HAMD-CL Driver HAM for use with the BAMD –25°C to +85°C 675 No
VI-HAM-ML Driver HAM –55°C to +85°C 675 No
VI-HAM-IL Driver HAM –40°C to +85°C 675 No
VI-HAM-EL Driver HAM –10°C to +85°C 675 No
VI-HAM-CL Driver HAM –25°C to +85°C 675 No
VI-BAMD-ML Booster HAM –55°C to +85°C 675 No
VI-BAMD-IL Booster HAM –40°C to +85°C 675 No
VI-BAMD-EL Booster HAM –10°C to +85°C 675 No
VI-BAMD-CL Booster HAM –25°C to +85°C 675 No
VE-HAMD-ML Driver HAM for use with the BAMD –55°C to +85°C 675 Yes
VE-HAMD-IL Driver HAM for use with the BAMD –40°C to +85°C 675 Yes
VE-HAMD-EL Driver HAM for use with the BAMD –10°C to +85°C 675 Yes
VE-HAMD-CL Driver HAM for use with the BAMD –25°C to +85°C 675 Yes
VE-HAM-ML Driver HAM –55°C to +85°C 675 Yes
VE-HAM-IL Driver HAM –40°C to +85°C 675 Yes
VE-HAM-EL Driver HAM –10°C to +85°C 675 Yes
VE-HAM-CL Driver HAM –25°C to +85°C 675 Yes
VE-BAMD-ML Booster HAM –55°C to +85°C 675 Yes
VE-BAMD-IL Booster HAM –40°C to +85°C 675 Yes
VE-BAMD-EL Booster HAM –10°C to +85°C 675 Yes
VE-BAMD-CL Booster HAM –25°C to +85°C 675 Yes
责任编辑:haq
