MAX9918, MAX9919, MAX9920 -20V
新品快讯
29人已加入
MAX9918, MAX9919, MAX9920 -20V至+75V输入范围、高精度单/双向电流检测放大器
概述
The MAX9918/MAX9919/MAX9920 are single-supply, high-accuracy current-sense amplifiers with a high input common-mode range that extends from -20V to +75V. These amplifiers are well suited for current monitoring of inductive loads such as motors and solenoids, where common-mode voltages can become negative due to inductive kickback, reverse-battery conditions, or transient events.
The MAX9918/MAX9920 feature adjustable gain set by an external resistive-divider network. The MAX9919 features fixed gains of 45V/V (MAX9919F) and 90V/V (MAX9919N). The MAX9918/MAX9919/MAX9920 operate as unidirectional amplifiers when VREFIN = GND and as bidirectional amplifiers when VREFIN = VCC/2. The MAX9920 attenuates the input signal by a factor of 4 at the input level shifting stage allowing the device to sense voltages up to 200mV (unidirectional operation) or ±100mV (bidirectional operation).
The MAX9918/MAX9919/MAX9920 operate with a single 5V supply voltage are fully specified over the -40°C to +125°C automotive temperature range, and are available in an 8-pin SOIC package.
关键特性
-20V to +75V Input Common-Mode Voltage Range
400µV (max) Input Offset Voltage
0.6% (max) Gain Accuracy Error
Uni- or Bidirectional Current Sensing
Reference Input for Bidirectional OUT
120kHz, -3dB Bandwidth (MAX9919N)
Single-Supply Operation (4.5V to 5.5V)
1mA Supply Current
0.5µA (typ) Shutdown Current
Rail-to-Rail Output
-40°C to +125°C Automotive Temperature Range
应用/使用
 4x4传输控制
 电感负载电流监测
 电子节气门控制
 H桥接电机电流检测
 高边、低边高精度电流检测
 精密的高压电流监测
 螺线管电流检测
 混合动力车中超级电容的充电/放电监测
MAX9918, MAX9919, MAX9920,pdf datasheet
检测放大器
Typical Operating Circuit
