ADRV9001原型软件维基页面
消耗积分:0 | 格式:pdf | 大小:141.63KB | 2021-03-23
分享资料个
This version (15 Jan 2021 21:19) was approved by Travis Collins.The Previously approved version (09 Jan 2021 00:32) is available.Diff
ADRV9001/2 Prototyping Platform User Guide
The ADRV9002NP/W1/PCBZ (low band, 30MHz – 3GHz) and ADRV9002NP/W2/PCBZ (high band, 3GHz – 6GHz) are FMC radio cards for the ADRV9002 highly integrated RF transceiver, offering dual channel transmitters and dual channel receivers, integrated synthesizers, and digital signal processing functions. The IC delivers a versatile combination of high performance and low power consumption required by battery powered radio equipment and can operate in both FDD and TDD modes. The ADRV9002 operates from 30 MHz to 6000 MHz covering the VHF, licensed and unlicensed cellular bands, and ISM bands. The IC is capable of supporting both narrowband and wideband standards up to 40MHz bandwidth on both receive and transmit.
While the complete chip level design package can be found on the ADI web site, information on the card and how to use it, the design package that surrounds it, and the software which can make it work can be found here.
User Resources
People who follow the flow that is outlined, have a much better experience with things. However, like many things, documentation is never as complete as it should be. If you have any questions, feel free to ask.
Downloads
Videos
Software Defined Radio using the Linux IIO Framework
ADI Articles
MathWorks Webinars
Warning
All the products described on this page include ESD (electrostatic discharge) sensitive devices. Electrostatic charges as high as 4000V readily accumulate on the human body or test equipment and can discharge without detection.
Although the boards feature ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. This includes removing static charge on external equipment, cables, or antennas before connecting to the device.
评论(0)
发评论
下载排行榜
