AD9737A评估板信息
消耗积分:0 | 格式:pdf | 大小:47.68KB | 2021-03-23
张燕
分享资料个
This version (23 Mar 2018 19:48) was approved by Michael Fowler.The Previously approved version (17 Jan 2014 18:17) is available.Diff
AD9739A & AD9737A Evaluation Board
Documentation and software updates for using the ad9739a ad9737a Evaluation Boards are included in a self-extracting update file. Documentation can also be downloaded individually below.
Files included in the AD9739A Update:
Download the AD9739A Update
Data Pattern Generator
The Data Pattern Generator (DPG) is a bench-top instrument for driving vectors into high-speed digital-to-analog converters. The DPG connects to a USB on a PC and allows a user to download a vector from the PC into the internal memory of the DPG. Once downloaded, the vector can be played out to an attached evaluation board for a specific DAC at full speed. This allows for rapid evaluation of the DAC with both generic and custom-generated test data.
For more information on the DPG line of pattern generators and software:
评论(0)
发评论
下载排行榜
