ADE120x软件驱动
消耗积分:0 | 格式:pdf | 大小:124.53KB | 2021-03-23
分享资料个
This version (03 Jan 2021 21:57) was approved by Robin Getz.The Previously approved version (11 Dec 2019 22:04) is available.Diff
ADE120x Supplemental User Guide
The ADE120x is an isolated binary input monitor. It performs an isolated measurement of a binary input voltage and communicates the status of this input to low voltage processors or logic circuits. The ADE120x application circuit can accept a wide range of binary input voltages from 10 V to 300 V scaled using a resistor divider before applying the voltage to the pins. This content applies to both ADE1201 and ADE1202.
评论(0)
发评论
下载排行榜
