使用LM1875的20W音频放大器(20W Audio Am
音频电路
144人已加入
使用LM1875的20W音频放大器(20W Audio Amplifier using LM1875)
Specifications
20W Audio Amplifier kit is based on LM1875 IC.
Power supply - 48 VDC
Output - 20 W, 4 Ω
Very low distortion (THD - 0.015%), good channel separation and ripple rejection
IC built-in thermal, short circuit protections
Internal output protection diodes
Terminal pins for connecting input
Power Battery Terminal (PBT) for easy power supply and speaker connection
Power-On LED indicator
Heatsink for IC
Four mounting holes of 3.2 mm each with nut and stud
PCB dimensions 48 mm x 60 mm
Schematic
Parts List
LM1875
