EV-COG-AD4050WZ用户指南
消耗积分:0 | 格式:pdf | 大小:114.79KB | 2021-04-09
王树林
分享资料个
This version (03 Jan 2021 22:07) was approved by Robin Getz.The Previously approved version (03 Sep 2018 08:02) is available.Diff
EV-COG-AD4050WZ Development Kit
The EV-COG-AD4050WZ (referred also as MCU Cog) is a development platform based on the industry leading ultra low power ADuCM4050 32-bit ARM Cortex™-M4F microcontroller. The platform is designed to be a development and prototyping vehicle to get customer ideas from concept to production with a minimal risk and faster time to market.
Applications using EV-COG-AD4050WZ board can be developed using one of the following toolchains.
  1. Crosscore Embedded Studio 2.7.0 and above - an Eclipse based Analog Devices Interactive Development Environment.
  2. IAR Embedded Workbench for ARM 8.20 and above
  3. Keil uVision 4 and above
  4. ARM mbed Compiler
Make sure a valid license for the selected toolchain is installed before using EV-COG-AD4050WZ board.
The software and power measurement is same for both EV-COG-AD4050WZ and EV-COG-AD4050LZ
  1. Software Packs & Board Support Package:EV-COG-AD4050WZ software architecture is categorized into 2 groups as below.
评论(0)
发评论
下载排行榜
