简述适用于极端温度和井下应用的高温晶体振荡器
今日头条
1100人已加入
Q-Tech Corporation为地下应用领域提供最先进性的高温混合晶体振荡器。产品包括规范数字时钟、实时时钟和音叉时钟频率。
Q-Tech振荡器设计在-55°C至+200°C的范围内(最大范围为+250°C)。Q-Tech高温振荡器是为极端环境设计的,例如井下钻井、高温航空电子设备、喷气发动机传感器、地热能源和工业应用领域。除去能够承担高温环境之外,Q-Tech振荡器还能抵御高冲击和振动。
Q-Tech产品都满足高可靠性设计、质量、按时交货和一流的顾客服务的高标准化。Q-Tech专注于为客户提供先进的频率控制解决方案。
深圳市立维创展科技有限公司授权代理销售Q-TECH产品,备用部分现货,欢迎与业界同行合作。
详情了解Q-Tech请点击:http://www.ldteq.com/public/brand/60.html
或联系我们的销售工程师:0755-83642657   QQ: 2295048674
Package Dimensions (mm) Market Device Type Logic Type Supply Voltage Stability Phase Noise Floor
QTCH230 2.50 x 3.20 x 1.15 High Temp XO CMOS 1.8 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QTCH230 (32K768) 2.50 x 3.20 x 1.15 High Temp XO CMOS 2.5 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QTCH350 3.20 x 5.00 x 1.20 High Temp XO CMOS 1.8 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QTCH350 (32K768) 3.20 x 5.00 x 1.20 High Temp XO CMOS 2.5 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QTCH570 5.00 x 7.00 x 1.40 High Temp XO CMOS 1.8 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QTCH570 (32K768) 5.00 x 7.00 x 1.40 High Temp XO CMOS 2.5 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QT1123L, QS1123L, QG1123L 22.35 x 12.83 x 5.08 High Temp XO - RTC CMOS -5.2 to -4.5Vdc & 1.8 to 15Vdc ±40ppm to ±250ppm Contact Q-Tech
QT2024 12.8 x 12.8 x 5.08 High Temp XO - RTC CMOS 3.3Vdc ±40ppm to ±250ppm Contact Q-Tech
QT380, QT381, QT382, QT383, QT384, QT385, QT386, QT387, QS380, QS381, QS382, QS383, QS384, QS385, QS386, QS387 5.0 x 7.0 x 2.54 High Temp XO - RTC CMOS 2.5 to 3.3Vdc ±150ppm to ±250ppm Contact Q-Tech
QT581, QT582, QT583, QT584, QT588, QT589, QT590, QT592, QS581, QS582, QS583, QS584, QS588, QS589, QS590, QS592 5.00 x 7.00 x 2.00 High Temp XO - RTC CMOS 2.5 to 3.3Vdc ±40ppm to ±250ppm Contact Q-Tech
QT81, QS81 5.00 x 7.00 x 2.00 High Temp 5x7 w/ 4pt Mount CMOS, LVHCMOS, TTL 1.8 to 5Vdc ±175ppm to ±450ppm Contact Q-Tech
QT86 5.00 x 7.00 x 2.00 High Temp 5x7 w/ 4pt Mount CMOS, LVHCMOS, TTL 1.8 to 5Vdc ±175ppm to ±450ppm Contact Q-Tech
编辑:jq
