DYTRAN 3056系列通用加速度计的特点
今日头条
1100人已加入
DYTRAN 3056系列是一款经济高效的单轴IEPE加速度计,具有TEDS功能。灵敏度范围从1mV/g到500mv/g
DYTRAN 3056系列设计将陶瓷剪切传感元件整合在坚固的钛壳中,具有10-32轴向连接器和10-32螺柱安装功能。DYTRAN 3056系列是基极隔离,以避免电磁干扰/接地回路干扰,并集成了低噪声JFET电子器件。该装置还密封,以实现在高湿度和肮脏环境中的可靠性能
特点:
气密
基础隔离
TEDS选项
TEDS
适用范围:
模态分析
振动控制
一般振动监测
深圳市立维创展科技有限公司,优势渠道提供DYTRAN传感器产品,欢迎咨询。
详情了解DYTRAN请点击:http://www.ldteq.com/public/brand/52.html
或联系我们的销售工程师:0755-83642657   QQ: 2295048674
电子器件MODEL SPECIFICATIONS
3056B10 10 mV/g sensitivity, 500g range, 10–32 axial connector, 1/4–28 mounting stud, mechanically and electrically filtered, 16 grams, isolated,–67 to +250°F Operation
3056B9 10 mV/g sensitivity, 500g range, 10–32 axial connector, M6 mounting stud, mechanically and electrically isolated, 16 grams, isolated,–67 to +250°F Operation
3056D1   10 mV/g sensitivity, 500g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D1T   10 mV/g sensitivity, 500g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
3056D2T   100 mV/g sensitivity, 50g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D2T   100 mV/g sensitivity, 50g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
3056D3   500 mV/g sensitivity, 10g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +225°F Operation
3056D3T   500 mV/g sensitivity, 10g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +225°F Operation,–40 to +185°F TEDS Operation
3056D4   20 mV/g sensitivity, 250g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D4T   20 mV/g sensitivity, 250g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
3056D5   50 mV/g sensitivity, 100g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D5T   50 mV/g sensitivity, 100g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
3056D6   200 mV/g sensitivity, 25g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +225°F Operation
3056D6T   200 mV/g sensitivity, 25g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +225°F Operation,–40 to +185°F TEDS Operation
3056D7   1 mV/g sensitivity, 5,000g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D7T   1 mV/g sensitivity, 5,000g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
3056D8   5 mV/g sensitivity, 1,000g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–67 to +250°F Operation
3056D8T   5 mV/g sensitivity, 1,000g range, 10–32 axial connector, 10–32 tapped hole, 10 grams, isolated,–60 to +250°F Operation,–40 to +185°F TEDS Operation
编辑:jq
