200W功率的灯闪光电路,200W Lamp Flasher
闪光灯电路
17人已加入
Specifications
  200W Lamp Flasher kit is used to flash lamps, bulbs and halogen lamp to give your product that attracting look.
Input supply - 6 ~ 12 VDC
Output - upto 200 W lamp / bulb load
Optically isolated Mains supply
Onboard preset to adjust the frequency (speed) of flashing (1 Hz to 5 Hz)
Power Battery Terminal (PBT) for easy input 230 VAC mains and load connection
Terminal pins for connecting DC power supply
Four mounting holes of 3.2 mm each
PCB dimensions 36 mm x 68 mm
Schematic
闪光电路
