golang的调度模型-GPM 模型的源码结构
  【导读】GMP 模型是让 go 语言轻量快速高效的重要调度模型,本文从 GMP 源码出发直观地解析了这一模型。
  这篇文章就来看看 golang 的调度模型-GPM 模型的源码结构。
  Go 版本:go1.13.9
  M 结构体
  M 结构体是 OS 线程的一个抽象,主要负责结合 P 运行 G。它里面有很多字段,差不多有 60 个字段,我们看看里面主要的字段意思。/src/runtime/runtime2.go
  Copytype m struct {
  // 系统管理的一个 g,执行调度代码时使用的。比如执行用户的 goroutine 时,就需要把把用户
  // 的栈信息换到内核线程的栈,以便能够执行用户 goroutine
  g0 *g // goroutine with scheduling stack
  morebuf gobuf // gobuf arg to morestack
  divmod uint32 // div/mod denominator for arm - known to liblink
  // Fields not known to debuggers.
  procid uint64 // for debuggers, but offset not hard-coded
  //处理 signal 的 g
  gsignal *g // signal-handling g
  goSigStack gsignalStack // Go-allocated signal handling stack
  sigmask sigset // storage for saved signal mask
  //线程的本地存储 TLS,这里就是为什么 OS 线程能运行 M 关键地方
  tls [6]uintptr // thread-local storage (for x86 extern register)
  //go 关键字运行的函数
  mstartfn func()
  //当前运行的用户 goroutine 的 g 结构体对象
  curg *g // current running goroutine
  caughtsig guintptr // goroutine running during fatal signal
  //当前工作线程绑定的 P,如果没有就为 nil
  p puintptr // attached p for executing go code (nil if not executing go code)
  //暂存与当前 M 潜在关联的 P
  nextp puintptr
  //M 之前调用的 P
  oldp puintptr // the p that was attached before executing a syscall
  id int64
  mallocing int32
  throwing int32
  //当前 M 是否关闭抢占式调度
  preemptoff string // if != “”, keep curg running on this m
  locks int32
  dying int32
  profilehz int32
  //M 的自旋状态,为 true 时 M 处于自旋状态,正在从其他线程偷 G; 为 false,休眠状态
  spinning bool // m is out of work and is actively looking for work
  blocked bool // m is blocked on a note
  newSigstack bool // minit on C thread called sigaltstack
  printlock int8
  incgo bool // m is executing a cgo call
  freeWait uint32 // if == 0, safe to free g0 and delete m (atomic)
  fastrand [2]uint32
  needextram bool
  traceback uint8
  ncgocall uint64 // number of cgo calls in total
  ncgo int32 // number of cgo calls currently in progress
  cgoCallersUse uint32 // if non-zero, cgoCallers in use temporarily
  cgoCallers *cgoCallers // cgo traceback if crashing in cgo call
  //没有 goroutine 运行时,工作线程睡眠
  //通过这个来唤醒工作线程
  park note // 休眠锁
  //记录所有工作线程的链表
  alllink *m // on allm
  schedlink muintptr
  //当前线程内存分配的本地缓存
  mcache *mcache
  //当前 M 锁定的 G,
  lockedg guintptr
  createstack [32]uintptr // stack that created this thread.
  lockedExt uint32 // tracking for external LockOSThread
  lockedInt uint32 // tracking for internal lockOSThread
  nextwaitm muintptr // next m waiting for lock
  waitunlockf func(*g, unsafe.Pointer) bool
  waitlock unsafe.Pointer
  waittraceev byte
  waittraceskip int
  startingtrace bool
  syscalltick uint32
  //操作系统线程 id
  thread uintptr // thread handle
  freelink *m // on sched.freem
  // these are here because they are too large to be on the stack
  // of low-level NOSPLIT functions.
  libcall libcall
  libcallpc uintptr // for cpu profiler
  libcallsp uintptr
  libcallg guintptr
  syscall libcall // stores syscall parameters on windows
  vdsoSP uintptr // SP for traceback while in VDSO call (0 if not in call)
  vdsoPC uintptr // PC for traceback while in VDSO call
  dlogPerM
  mOS
  看看几个比较重要的字段:g0:用于执行调度器的 g0gsignal:用于信号处理tls:线程本地存储的 tlsp:goroutine 绑定的本地资源
  P 结构体
  一个 M 要运行,必须绑定 P 才能运行 goroutine,M 阻塞时,P 会被传给其他 M。
  Copytype p struct {
  //allp 中的索引
  id int32
  //p 的状态
  status uint32 // one of pidle/prunning/。。.
  link puintptr
  schedtick uint32 // incremented on every scheduler call-》每次 scheduler 调用+1
  syscalltick uint32 // incremented on every system call-》每次系统调用+1
  sysmontick sysmontick // last tick observed by sysmon
  //指向绑定的 m,如果 p 是 idle 的话,那这个指针是 nil
  m muintptr // back-link to associated m (nil if idle)
  mcache *mcache
  raceprocctx uintptr
  //不同大小可用 defer 结构池
  deferpool [5][]*_defer // pool of available defer structs of different sizes (see panic.go)
  deferpoolbuf [5][32]*_defer
  // Cache of goroutine ids, amortizes accesses to runtime·sched.goidgen.
  goidcache uint64
  goidcacheend uint64
  //本地运行队列,可以无锁访问
  // Queue of runnable goroutines. Accessed without lock.
  runqhead uint32 //队列头
  runqtail uint32 //队列尾
  //数组实现的循环队列
  runq [256]guintptr
  // runnext, if non-nil, is a runnable G that was ready‘d by
  // the current G and should be run next instead of what’s in
  // runq if there‘s time remaining in the running G’s time
  // slice. It will inherit the time left in the current time
  // slice. If a set of goroutines is locked in a
  // communicate-and-wait pattern, this schedules that set as a
  // unit and eliminates the (potentially large) scheduling
  // latency that otherwise arises from adding the ready‘d
  // goroutines to the end of the run queue.
  // runnext 非空时,代表的是一个 runnable 状态的 G,
  //这个 G 被 当前 G 修改为 ready 状态,相比 runq 中的 G 有更高的优先级。
  //如果当前 G 还有剩余的可用时间,那么就应该运行这个 G
  //运行之后,该 G 会继承当前 G 的剩余时间
  runnext guintptr
  // Available G’s (status == Gdead)
  //空闲的 g
  gFree struct {
  gList
  n int32
  sudogcache []*sudog
  sudogbuf [128]*sudog
  tracebuf traceBufPtr
  // traceSweep indicates the sweep events should be traced.
  // This is used to defer the sweep start event until a span
  // has actually been swept.
  traceSweep bool
  // traceSwept and traceReclaimed track the number of bytes
  // swept and reclaimed by sweeping in the current sweep loop.
  traceSwept, traceReclaimed uintptr
  palloc persistentAlloc // per-P to avoid mutex
  _ uint32 // Alignment for atomic fields below
  // Per-P GC state
  gcAssistTime int64 // Nanoseconds in assistAlloc
  gcFractionalMarkTime int64 // Nanoseconds in fractional mark worker (atomic)
  gcBgMarkWorker guintptr // (atomic)
  gcMarkWorkerMode gcMarkWorkerMode
  // gcMarkWorkerStartTime is the nanotime() at which this mark
  // worker started.
  gcMarkWorkerStartTime int64
  // gcw is this P‘s GC work buffer cache. The work buffer is
  // filled by write barriers, drained by mutator assists, and
  // disposed on certain GC state transitions.
  gcw gcWork
  // wbBuf is this P’s GC write barrier buffer.
  // TODO: Consider caching this in the running G.
  wbBuf wbBuf
  runSafePointFn uint32 // if 1, run sched.safePointFn at next safe point
  pad cpu.CacheLinePad
  其他的一些字段就是 gc,trace,debug 信息
  G 结构体
  G 就是 goroutine。主要保存 goroutine 的所有信息以及栈信息,gobuf 结构体:cpu 里的寄存器信息,以便在轮到本 goroutine 执行时,知道从哪里开始执行。
  Copytype stack struct {
  lo uintptr //栈顶,指向内存低地址
  hi uintptr //栈底,指向内存搞地址
  type g struct {
  // Stack parameters.
  // stack describes the actual stack memory: [stack.lo, stack.hi)。
  // stackguard0 is the stack pointer compared in the Go stack growth prologue.
  // It is stack.lo+StackGuard normally, but can be StackPreempt to trigger a preemption.
  // stackguard1 is the stack pointer compared in the C stack growth prologue.
  // It is stack.lo+StackGuard on g0 and gsignal stacks.
  // It is ~0 on other goroutine stacks, to trigger a call to morestackc (and crash)。
  // 记录该 goroutine 使用的栈
  stack stack // offset known to runtime/cgo
  //下面两个成员用于栈溢出检查,实现栈的自动伸缩,抢占调度也会用到 stackguard0
  stackguard0 uintptr // offset known to liblink
  stackguard1 uintptr // offset known to liblink
  _panic *_panic // innermost panic - offset known to liblink
  _defer *_defer // innermost defer
  // 此 goroutine 正在被哪个工作线程执行
  m *m // current m; offset known to arm liblink
  //这个字段跟调度切换有关,G 切换时用来保存上下文,保存什么,看下面 gobuf 结构体
  sched gobuf
  syscallsp uintptr // if status==Gsyscall, syscallsp = sched.sp to use during gc
  syscallpc uintptr // if status==Gsyscall, syscallpc = sched.pc to use during gc
  stktopsp uintptr // expected sp at top of stack, to check in traceback
  param unsafe.Pointer // passed parameter on wakeup,wakeup 唤醒时传递的参数
  // 状态 Gidle,Grunnable,Grunning,Gsyscall,Gwaiting,Gdead
  atomicstatus uint32
  stackLock uint32 // sigprof/scang lock; TODO: fold in to atomicstatus
  goid int64
  //schedlink 字段指向全局运行队列中的下一个 g,
  //所有位于全局运行队列中的 g 形成一个链表
  schedlink guintptr
  waitsince int64 // approx time when the g become blocked
  waitreason waitReason // if status==Gwaiting,g 被阻塞的原因
  //抢占信号,stackguard0 = stackpreempt,如果需要抢占调度,设置 preempt 为 true
  preempt bool // preemption signal, duplicates stackguard0 = stackpreempt
  paniconfault bool // panic (instead of crash) on unexpected fault address
  preemptscan bool // preempted g does scan for gc
  gcscandone bool // g has scanned stack; protected by _Gscan bit in status
  gcscanvalid bool // false at start of gc cycle, true if G has not run since last scan; TODO: remove?
  throwsplit bool // must not split stack
  raceignore int8 // ignore race detection events
  sysblocktraced bool // StartTrace has emitted EvGoInSyscall about this goroutine
  sysexitticks int64 // cputicks when syscall has returned (for tracing)
  traceseq uint64 // trace event sequencer
  tracelastp puintptr // last P emitted an event for this goroutine
  // 如果调用了 LockOsThread,那么这个 g 会绑定到某个 m 上
  lockedm muintptr
  sig uint32
  writebuf []byte
  sigcode0 uintptr
  sigcode1 uintptr
  sigpc uintptr
  // 创建这个 goroutine 的 go 表达式的 pc
  gopc uintptr // pc of go statement that created this goroutine
  ancestors *[]ancestorInfo // ancestor information goroutine(s) that created this goroutine (only used if debug.tracebackancestors)
  startpc uintptr // pc of goroutine function
  racectx uintptr
  waiting *sudog // sudog structures this g is waiting on (that have a valid elem ptr); in lock order
  cgoCtxt []uintptr // cgo traceback context
  labels unsafe.Pointer // profiler labels
  timer *timer // cached timer for time.Sleep, 为 time.Sleep 缓存的计时器
  selectDone uint32 // are we participating in a select and did someone win the race?
  // Per-G GC state
  // gcAssistBytes is this G‘s GC assist credit in terms of
  // bytes allocated. If this is positive, then the G has credit
  // to allocate gcAssistBytes bytes without assisting. If this
  // is negative, then the G must correct this by performing
  // scan work. We track this in bytes to make it fast to update
  // and check for debt in the malloc hot path. The assist ratio
  // determines how this corresponds to scan work debt.
  gcAssistBytes int64
  gobuf
  gobuf 结构体用于保存 goroutine 的调度信息,主要包括 CPU 的几个寄存器的值。
  Copytype gobuf struct {
  // The offsets of sp, pc, and g are known to (hard-coded in) libmach.
  // ctxt is unusual with respect to GC: it may be a
  // heap-allocated funcval, so GC needs to track it, but it
  // needs to be set and cleared from assembly, where it’s
  // difficult to have write barriers. However, ctxt is really a
  // saved, live register, and we only ever exchange it between
  // the real register and the gobuf. Hence, we treat it as a
  // root during stack scanning, which means assembly that saves
  // and restores it doesn‘t need write barriers. It’s still
  // typed as a pointer so that any other writes from Go get
  // write barriers.
  sp uintptr // 保存 CPU 的 rsp 寄存器的值
  pc uintptr // 保存 CPU 的 rip 寄存器的值
  g guintptr // 记录当前这个 gobuf 对象属于哪个 goroutine
  ctxt unsafe.Pointer
  //保存系统调用的返回值,因为从系统调用返回之后如果 p 被其它工作线程抢占,
  //则这个 goroutine 会被放入全局运行队列被其它工作线程调度,其它线程需要知道系统调用的返回值。
  ret sys.Uintreg // 保存系统调用的返回值
  lr uintptr
  //保存 CPU 的 rip 寄存器的值
  bp uintptr // for GOEXPERIMENT=framepointer
  调度器 sched 结构
  所有的 gorouteine 都是被调度器调度运行,调度器持有全局资源
  sched
  Copytype schedt struct {
  // accessed atomically. keep at top to ensure alignment on 32-bit systems.
  // 需以原子访问访问。
  // 保持在 struct 顶部,以使其在 32 位系统上可以对齐
  goidgen uint64
  lastpoll uint64
  lock mutex
  // When increasing nmidle, nmidlelocked, nmsys, or nmfreed, be
  // sure to call checkdead()。
  //由空闲的工作线程组成的链表
  midle muintptr // idle m‘s waiting for work
  //空闲的工作线程的数量
  nmidle int32 // number of idle m’s waiting for work
  //空闲的且被 lock 的 m 计数
  nmidlelocked int32 // number of locked m‘s waiting for work
  //已经创建的多个 m,下一个 m id
  mnext int64 // number of m’s that have been created and next M ID
  //被允许创建的最大 m 线程数量
  maxmcount int32 // maximum number of m‘s allowed (or die)
  nmsys int32 // number of system m’s not counted for deadlock
  //累积空闲的 m 数量
  nmfreed int64 // cumulative number of freed m‘s
  //系统 goroutine 的数量,自动更新
  ngsys uint32 // number of system goroutines; updated atomically
  //由空闲的 p 结构体对象组成的链表
  pidle puintptr // idle p’s
  //空闲的 p 结构体对象的数量
  npidle uint32
  nmspinning uint32 // See “Worker thread parking/unparking” comment in proc.go.
  // Global runnable queue.
  //全局运行队列 G 队列
  runq gQueue //这个结构体在 proc.go 里
  //元素数量
  runqsize int32
  // disable controls selective disabling of the scheduler.
  // Use schedEnableUser to control this.
  // disable is protected by sched.lock.
  disable struct {
  // user disables scheduling of user goroutines.
  user bool
  runnable gQueue // pending runnable Gs
  n int32 // length of runnable
  // Global cache of dead G‘s. 有效 dead G 全局缓存
  gFree struct {
  lock mutex
  stack gList // Gs with stacks
  noStack gList // Gs without stacks
  n int32
  // Central cache of sudog structs. dusog 结构的集中缓存
  sudoglock mutex
  sudogcache *sudog
  // Central pool of available defer structs of different sizes. 不同大小有效的 defer 结构的池
  deferlock mutex
  deferpool [5]*_defer
  // freem is the list of m’s waiting to be freed when their
  // m.exited is set. Linked through m.freelink.
  freem *m
  gcwaiting uint32 // gc is waiting to run
  stopwait int32
  stopnote note
  sysmonwait uint32
  sysmonnote note
  // safepointFn should be called on each P at the next GC
  // safepoint if p.runSafePointFn is set.
  safePointFn func(*p)
  safePointWait int32
  safePointNote note
  profilehz int32 // cpu profiling rate
  procresizetime int64 // nanotime() of last change to gomaxprocs
  totaltime int64 // ∫gomaxprocs dt up to procresizetime
  gQueue
  /src/runtime/proc.go
  Copytype gQueue struct {
  head guintptr //队列头
  tail guintptr //队列尾
  一些重要全局变量
  Copym0 m //代表主线程
  g0 g //m0 绑定的 g0,也就是 M 结构体中 m0.g0=&g0
  allgs []*g //保存所有的 g
  Copyallm *m //所有的 m 构成的一个链表,包括上面的 m0
  allp []*p //保存所有的 p, len(allp) == gomaxprocs
  sched schedt //调度器的结构体,保存了调度器的各种信息
  ncpu int32 //系统 cpu 核的数量,程序启动时由 runtime 初始化
  gomaxprocs int32 //p 的最大数量,默认等于 ncpu,可以通过 GOMAXPROCS 修改
  在程序初始化时,这些变量都会被初始化为 0 值,指针会被初始化为 nil 指针,切片初始化为 nil 切片,int 被初始化为数字 0,结构体的所有成员变量按其本类型初始化为其类型的 0 值。
  调度器初始化
  调度器初始化有一个主要的函数 schedinit(), 这个函数在 /src/runtime/proc.go 文件中。函数开头还把初始化的顺序给列出来了:
  // The bootstrap sequence is://// call osinit// call schedinit// make & queue new G// call runtime·mstart//// The new G calls runtime·main.
  Copyfunc schedinit() {
  // raceinit must be the first call to race detector.
  // In particular, it must be done before mallocinit below calls racemapshadow.
  _g_ := getg() //getg() 在 src/runtime/stubs.go 中声明,真正的代码由编译器生成
  if raceenabled {
  _g_.racectx, raceprocctx0 = raceinit()
  //设置最大 M 的数量
  sched.maxmcount = 10000
  tracebackinit()
  moduledataverify()
  //初始化栈空间常用管理链表
  stackinit()
  mallocinit()
  //初始化当前 m
  mcommoninit(_g_.m)
  cpuinit() // must run before alginit
  alginit() // maps must not be used before this call
  modulesinit() // provides activeModules
  typelinksinit() // uses maps, activeModules
  itabsinit() // uses activeModules
  msigsave(_g_.m)
  initSigmask = _g_.m.sigmask
  goargs()
  goenvs()
  parsedebugvars()
  gcinit()
  sched.lastpoll = uint64(nanotime())
  // 把 p 数量从 1 调整到默认的 CPU Core 数量
  procs := ncpu
  if n, ok := atoi32(gogetenv(“GOMAXPROCS”)); ok && n 》 0 {
  procs = n
  //调整 P 数量
  //这里的 P 都是新建的,所以不返回有本地任务的 p
  if procresize(procs) != nil {
  throw(“unknown runnable goroutine during bootstrap”)
  // For cgocheck 》 1, we turn on the write barrier at all times
  // and check all pointer writes. We can‘t do this until after
  // procresize because the write barrier needs a P.
  if debug.cgocheck 》 1 {
  writeBarrier.cgo = true
  writeBarrier.enabled = true
  for _, p := range allp {
  p.wbBuf.reset()
  if buildVersion == “” {
  // Condition should never trigger. This code just serves
  // to ensure runtime·buildVersion is kept in the resulting binary.
  buildVersion = “unknown”
  if len(modinfo) == 1 {
  // to ensure runtime·modinfo is kept in the resulting binary.
  modinfo = “”
  开头的这个函数 getg(),跳转到了 func getg() *g ,定义这么一个形式,什么意思?函数首先调用 getg() 函数获取当前正在运行的 g,getg() 在 src/runtime/stubs.go 中声明,真正的代码由编译器生成。
  Copy// getg returns the pointer to the current g.// The compiler rewrites calls to this function into instructions// that fetch the g directly (from TLS or from the dedicated register).func getg() *g
  注释里也说了,getg 返回当前正在运行的 goroutine 的指针,它会从 tls 里取出 tls[0],也就是当前运行的 goroutine 的地址。编译器插入类似下面的代码:
  Copyget_tls(CX)
  MOVQ g(CX), BX; // BX 存器里面现在放的是当前 g 结构体对象的地址
  原来是这么个意思。
  调度器初始化大致过程:M 初始化 --》 P 初始化 - -》 G 初始化mcommoninit Procresize newproc-------------------------------------------------------allm 池 allp 池 g.sched 执行现场p.runq 调度队列
  M/P/G 初始化:mcommoninit、procresize、newproc,他们负责 M 资源池(allm)、p 资源池(allp)、G 的运行现场(g.sched) 以及调度队列(p.runq)
  调度循环
  所有的工作初始化完成后,就要启动运行器了。准备工作做好了,就要启动 mstart 了。这个工作在汇编语言中也可以看出来
  /src/runtime/asm_amd64.s (在 linux 下)
  CopyTEXT runtime·rt0_go(SB),NOSPLIT,$0
  MOVL 16(SP), AX // copy argc
  MOVL AX, 0(SP)
  MOVQ 24(SP), AX // copy argv
  MOVQ AX, 8(SP)
  CALL runtime·args(SB)
  CALL runtime·osinit(SB) //OS 初始化
  CALL runtime·schedinit(SB) //调度器初始化
  // create a new goroutine to start program
  MOVQ $runtime·mainPC(SB), AX // entry
  PUSHQ AX
  PUSHQ $0 // arg size
  CALL runtime·newproc(SB) // G 初始化
  POPQ AX
  // start this M , 启动 M
  CALL runtime·mstart(SB)
  CALL runtime·abort(SB) // mstart should never return
  RET
  转自:九卷
  cnblogs.com/jiujuan/p/12977832.html
  编辑:jq
