stm325个串口的配置函数 STM32串口如何发送数据
1.2w人已加入
  5个串口的配置函数和收发数据函数代码:
  #include “stm32f10x.h”
  #include “misc.h”
  #include “stm32f10x_gpio.h”
  #include “stm32f10x_usart.h”
  void USART1_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  USART_InitTypeDef USART_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE );
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入;
  USART_InitStructure.USART_BaudRate = 9600; //波特率;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位;
  USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位;
  USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  //无硬件流控;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  //收发模式;
  USART_Init(USART1, &USART_InitStructure);//配置串口参数;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级;
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //中断号;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART1, ENABLE); //使能串口;
  void USART1_Send_Byte(u8 Data) //发送一个字节;
  USART_SendData(USART1,Data);
  while( USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET );
  void USART1_Send_String(u8 *Data) //发送字符串;
  while(*Data)
  USART1_Send_Byte(*Data++);
  void USART1_IRQHandler(void) //中断处理函数;
  u8 res;
  if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET) //判断是否发生中断;
  USART_ClearFlag(USART1, USART_IT_RXNE); //清除标志位;
  res=USART_ReceiveData(USART1); //接收数据;
  USART1_Send_Byte(res); //用户自定义;
  void USART2_Configuration(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE );
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //USART2 TX;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //USART2 RX;
  //无硬件流控;
  //收发模式;
  USART_Init(USART2, &USART_InitStructure);//配置串口参数;
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //中断号;
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART2, ENABLE); //使能串口;
  void USART2_Send_Byte(u8 Data) //发送一个字节;
  USART_SendData(USART2,Data);
  while( USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET );
  void USART2_Send_String(u8 *Data) //发送字符串;
  while(*Data)
  USART2_Send_Byte(*Data++);
  void USART2_IRQHandler(void) //中断处理函数;
  u8 res;
  if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET) //判断是否发生中断;
  USART_ClearFlag(USART2, USART_IT_RXNE); //清除标志位;
  res=USART_ReceiveData(USART2); //接收数据;
  USART2_Send_Byte(res); //用户自定义;
  void USART3_Configuration(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE );
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE );
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART3 TX;
  GPIO_Init(GPIOB, &GPIO_InitStructure); //端口B;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //USART3 RX;
  //无硬件流控;
  //收发模式;
  USART_Init(USART3, &USART_InitStructure);//配置串口参数;
  NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; //中断号;
  USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART3, ENABLE); //使能串口;
  void USART3_Send_Byte(u8 Data) //发送一个字节;
  USART_SendData(USART3,Data);
  while( USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET );
  void USART3_Send_String(u8 *Data) //发送字符串;
  while(*Data)
  USART3_Send_Byte(*Data++);
  void USART3_IRQHandler(void) //中断处理函数;
  u8 res;
  if(USART_GetITStatus(USART3, USART_IT_RXNE) == SET) //判断是否发生中断;
  USART_ClearFlag(USART3, USART_IT_RXNE); //清除标志位;
  res=USART_ReceiveData(USART3); //接收数据;
  USART3_Send_Byte(res); //用户自定义;
  void UART4_Configuration(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE );
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE );
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //UART4 TX;
  GPIO_Init(GPIOC, &GPIO_InitStructure); //端口C;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //UART4 RX;
  //无硬件流控;
  //收发模式;
  USART_Init(UART4, &USART_InitStructure);//配置串口参数;
  NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn; //中断号;
  USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
  USART_Cmd(UART4, ENABLE); //使能串口;
  void UART4_Send_Byte(u8 Data) //发送一个字节;
  USART_SendData(UART4,Data);
  while( USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET );
  void UART4_Send_String(u8 *Data) //发送字符串;
  while(*Data)
  UART4_Send_Byte(*Data++);
  void UART4_IRQHandler(void) //中断处理函数;
  u8 res;
  if(USART_GetITStatus(UART4, USART_IT_RXNE) == SET) //判断是否发生中断;
  USART_ClearFlag(UART4, USART_IT_RXNE); //清除标志位;
  res=USART_ReceiveData(UART4); //接收数据;
  UART4_Send_Byte(res); //用户自定义;
  void UART5_Configuration(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE );
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART5, ENABLE );
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //UART5 TX;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //UART5 RX;
  GPIO_Init(GPIOD, &GPIO_InitStructure); //端口D;
  //无硬件流控;
  //收发模式;
  USART_Init(UART5, &USART_InitStructure);//配置串口参数;
  NVIC_InitStructure.NVIC_IRQChannel = UART5_IRQn; //中断号;
  USART_ITConfig(UART5, USART_IT_RXNE, ENABLE);
  USART_Cmd(UART5, ENABLE); //使能串口;
  void UART5_Send_Byte(u8 Data) //发送一个字节;
  USART_SendData(UART5,Data);
  while( USART_GetFlagStatus(UART5, USART_FLAG_TC) == RESET );
  void UART5_Send_String(u8 *Data) //发送字符串;
  while(*Data)
  UART5_Send_Byte(*Data++);
  void UART5_IRQHandler(void) //中断处理函数;
  u8 res;
  if(USART_GetITStatus(UART5, USART_IT_RXNE) == SET) //判断是否发生中断;
  USART_ClearFlag(UART5, USART_IT_RXNE); //清除标志位;
  res=USART_ReceiveData(UART5); //接收数据;
  UART5_Send_Byte(res); //用户自定义;
  STM32串口发送数据
  1. 串口发送数据最直接的方式就是标准调用库函数 。
  void Send_data(u8 *s)
  while(*s!=‘\0’)
  while(USART_GetFlagStatus(USART1,USART_FLAG_TC )==RESET);
  USART_SendData(USART1,*s);
  s++;
  2. 直接使用printf函数。
STM32
  整合自:CSDNSumjess、可以吃的鱼
  编辑:jq
