MAX306, MAX307 高精度、16通道/双8通道、高
新品快讯
29人已加入
MAX306, MAX307 高精度、16通道/双8通道、高性能、CMOS模拟多路复用器
NO(OFF) less than 2.5nA at +85°C) and fast switching speeds (tTRANS less than 250ns). The MAX306 is a single-ended 1-of-16 device, and the MAX307 is a differential 2-of-8 device.
The MAX306/MAX307 are fabricated with Maxim's improved 44V silicon-gate process. Design improvements yield extremely low charge injection (less than 10pC) and guarantee electrostatic discharge (ESD) protection greater than 2000V.
These muxes operate with a single +5V to +30V supply, or bipolar ±4.5V to ±20V supplies, while retaining TTL/CMOS-logic input compatibility and fast switching. CMOS inputs provide reduced input loading. These improved parts are plug-in upgrades for the industry-standard DG406, DG407, DG506A, and DG507A.
  • Guaranteed On-Resistance Match Between Channels, < 5 Ω Max
  • Low On-Resistance, < 100Ω Max
  • Guaranteed Flat On-Resistance over Specified Signal Range, 7Ω Max
  • Guaranteed Charge Injection, < 10pC
  • INO(OFF) Leakage < 2.5nA at +85°C
  • ICOM(OFF) Leakage < 20nA at +85°C
  • ESD Protection > 2000V
  • Plug-In Upgrade for Industry-Standard DG406/DG407/DG506A/DG507A
  • Single-Supply Operation (+5V to +30V)
  • Bipolar-Supply Operation (±4.5V to ±20V)
  • Low Power Consumption, < 1.25mW
  • Rail-to-Rail Signal Handling
  • TTL/CMOS-Logic Compatible
  • 音频信号切换
    电池供电系统
    通信系统
    引导与控制系统
    平面显示器
    军用无线装置
    PBX、PABX
    采样保持电路
    测试设备
    多路复用器
    引脚配置
    多路复用器
    引脚配置
