STM32步进电机驱动的算法
1.2w人已加入
  在脉冲模式下,步进电机启动器的脉冲频率与速度成正比,函数void CalculateSModelLine(float fre[],  unsigned short period[],   float  len,  float fre_max,  float fre_min, float flexible)主要目的就是生成每一个细分步加速的速度。芯片用的是stm32f103c8t6,驱动器用的是2DM420。
   程序流程如下:
  •   STM32硬件基本初始化,主要是针对定时器
  •   调用函数CalculateSModelLine()生 成每一个细分步定时器的自动重装载值(实际就是改变脉冲的周期)
  •   打开定时器
  •   更新中断发生,将数组中的数据赋值给定时器的自动重装载寄存器
  •   跳出中断后脉冲频频率就变化了
  •   下一次更新中断产生
  对应的计算接口code:
  /*  calculate the Period and Freq array value, fill the Period value into the Period register during the timer interrupt.
  *calculate the acceleration procedure , a totally 1000 elements array.
  * parameter    fre[]: point to the array that keeps the freq value.
  *   period[]: point to the array that keeps the timer period value.
  *   len: the procedure of acceleration length.it is best thing to set the float number, some compile software maybe transfer error if set it as a int
  *   fre_max: maximum speed, frequency vale.
  *   fre_min: start minimum speed, frequency vale.  mind : 10000000/65535 = 152, so fre_min can't less than 152.
  *   flexible:  flexible value. adjust the S curves
  int i=0;
  float deno ;
  float melo ;
  float delt = fre_max-fre_min;
  for(; i;>
  melo = flexible * (i-len/2) / (len/2);
  deno = 1.0 / (1 + expf(-melo));   //expf is a library function of exponential(e)
  fre[i] = delt * deno + fre_min;
  period[i] = (unsigned short)(10000000.0 / fre[i]);    // 10000000 is the timer driver frequency
  return ;
  文章整合自:CSDN
编辑:ymf
