基于MIC5163_Typical Application直流到直流单输出电源的参考设计
消耗积分:0 | 格式:pdf | 大小:447.32KB | 2021-08-11
分享资料个
说明
  • Typical Application for MIC5163 is a dual regulator controller designed specifically for low voltage memory termination applications such as DDR3 and GDDR3/4/5. The MIC5163 offers a simple, low cost JEDEC compliant solution for terminating high-speed, low-voltage digital buses. The MIC5163 controls two external N-Channel MOSFETs to form two separate regulators. It operates by switching between either the high-side MOSFET or the low-side MOSFET, depending on whether the current is being sourced to the load or being sinked by the regulator
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    0.75 to 6 V
评论(0)
发评论
下载排行榜
