基于L7986TA_Typical Application直流到直流单输出电源的参考设计
消耗积分:0 | 格式:pdf | 大小:1.25MB | 2021-09-06
分享资料个
说明
  • Typical Application for the L7986TA is a step-down switching regulator with 3.7A (min.) current limited embedded Power MOSFET, so it is able to deliver up to 3A current to the load depending on the application conditions. The input voltage can range from 4.5 to 38 V, while the output voltage can be set starting from 0.6V to VIN
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    4.5 to 38 V
  • Output Voltage
    0.6 V
  • Output Current
    3 A
  • Topology
    Buck
评论(0)
发评论
下载排行榜
