TOP255YN(252-262)-电源管理芯片(英文版)
消耗积分:0 | 格式:pdf | 大小:53.41KB | 2021-09-23
ah此生不换
分享资料个
TOP255YN(252-262)-电源管理芯片(英文版)-
Product Highlights
Lower System Cost,Hlgher Design Flexlblty
·Multi-mode operation maximizes efficiency at all loads
·New eSIP-7F and eSIP-7C packages
·Low thermal impedance junction-to-case(2C per watt)
·Low helght ls Ideal for adapters where space Is lmited
·SImple mounting using a cllp to ald low cost manufacturing
·Hortzontal eSIP-7F package ideal for ultra low helght adapter and monitor applications
·Extended package creepage distance from DRAIN pin to adjacent pin and to heat sink
·No heat sink requlred up to 35 W using P,G and M packages with unlversal Input voltage and up to 48 W at 230 VAC
·Output overvoltage protection (OVP)Is user programmable for latching/non-latching shutdown with fast AC reset
部分文件列表
文件名 大小
TOP255YN-电源管理芯片.pdf 14M
评论(0)
发评论
下载排行榜
