Linux中如何用vim做golang开发环境
vim 做 golang 开发环境,多么炫酷!还没尝试过用 vim 做开发环境的同学可以跟着这篇文档把环境搭建起来了!
准备条件,是已经安装好 golang 环境,还需要把 golang 的环境变量配置好,这里配置如下
[root@localhost bundle]# vim /etc/profile
在这个文件最后加上,GOPATH、GOBIN、GOROOT、PATH 的环境变量
export GOPATH=“/root/go”export GOBIN=“$GOPATH/bin”export GOROOT=“/usr/local/go”export PATH=“$PATH:/usr/local/go/bin”export PATH=“$PATH:/root/go/bin”
[root@localhost bundle]# source /etc/profile
安装 git
[root@localhost ~]# yum install -y git
安装 Vundle.vim
mkdir ~/.vim/bundle
git clone https://github.com/gmarik/Vundle.vim.git ~/.vim/bundle/Vundle.vim
安装 vim-go
git clone https://github.com/fatih/vim-go.git ~/.vim/bundle/vim-go
修改~/.vimrc,如果没有就创建。vimrc 文件
[root@localhost bundle]# vim ~/.vimrcset nocompatible “ be iMproved, required
filetype off ” required
“ set the runtime path to include Vundle and initialize
set rtp+=~/.vim/bundle/Vundle.vim
call vundle#begin()
” let Vundle manage Vundle, required
Plugin ‘gmarik/Vundle.vim’
Plugin ‘fatih/vim-go’“ All of your Plugins must be added before the following line
call vundle#end() ” required
filetype plugin indent on “ required
let g:go_version_warning = 0
如果觉得高亮的地方太少,可在~/.vimrc 下多添加如下配置
let g:go_highlight_functions = 1
let g:go_highlight_methods = 1
let g:go_highlight_structs = 1
let g:go_highlight_operators = 1
let g:go_highlight_build_constraints = 1
创建一个测试文件 test.go,将发现可以高亮了
[root@localhost bundle]# vim 。/test.go
下载 nerdtree 和 nerdtree-git-plugin
[root@localhost bundle]# git clone https://github.com/scrooloose/nerdtree.git ~/.vim/bundle/nerdtree
[root@localhost bundle]# git clone https://github.com/Xuyuanp/nerdtree-git-plugin.git ~/.vim/bundle/nerdtree-git-plugin
修改~/.vimrc
set nocompatible ” be iMproved, required
filetype off “ required
” set the runtime path to include Vundle and initialize
call vundle#begin()
“ let Vundle manage Vundle, required
Plugin ‘git://github.com/scrooloose/nerdtree.git’
Plugin ‘git://github.com/Xuyuanp/nerdtree-git-plugin.git’” All of your Plugins must be added before the following line
call vundle#end() “ required
filetype plugin indent on ” required
“ NERDTree config
map 《F7》 :NERDTreeToggle《CR》 ”快捷键 F7,可以收放目录树的视图
autocmd bufenter * if (winnr(“$”) == 1 && exists(“b:NERDTreeType”) &&b:NERDTreeType == “primary”) | q | endif
autocmd vimenter * NERDTree
nerdtree 的使用,这里不讲解,大家可使用?命令来自己了解,如下
注意:使用 nerdtree 的命令,需要光标在目录树的窗口下才可以,如上图,此时直接敲?即可
安装 neocomplete
这个智能的提示功能需要很多限制条件,想要安装成功请先阅读这个网址:
https://blog.csdn.net/pei2215015/article/details/79813522
根据官网 https://github.com/shougo/neosnippet.vim 的提示安装,修改~/.vimrc
在如上位置添加 3 个插件 Plugin
在~/.vimrc 文件的最后添加
let g:neocomplete#enable_at_startup = 1
:wq 保存退出
打开 vim,执行:PluginInstall
[root@localhost .vim]# vim
:PluginInstall
出现 Done 即安装成功
安装 ctags、gotags 和 tarbar
[root@localhost bundle]# yum install -y ctags
如上面第 9 个步骤一样,在~/.vimrc 中添加插件
Plugin ‘jstemmer/gotags’
Plugin ‘majutsushi/tagbar’
保存之后,打开 vim,执行:PluginInstall,如下
:PluginInstall
出现 Done 即安装成功
在~/.vimrc文件最后加入以下内容:
let g:tagbar_type_go = {
‘ctagstype’ : ‘go’,
‘kinds’ : [
‘p:package’,
‘i1’,
‘c:constants’,
‘v:variables’,
‘t:types’,
‘n:interfaces’,
‘w:fields’,
‘e:embedded’,
‘m:methods’,
‘r:constructor’,
‘f:functions’
‘sro’ : ‘。’,
‘kind2scope’ : {
‘t’ : ‘ctype’,
‘n’ : ‘ntype’
‘scope2kind’ : {
‘ctype’ : ‘t’,
‘ntype’ : ‘n’
‘ctagsbin’ : ‘gotags’,
‘ctagsargs’ : ‘-sort -silent’
安装 mark.vim
地址:https://www.vim.org/scripts/script.php?script_id=2666,我这里演示中下载的是
直接使用 vim 打开
[root@localhost bundle]# vim 。/mark-3.0.0.vmb.gz
在 vim 的命令模式下输入
:so %
即安装成功
在~/.vimrc 中添加
nmap ml 《Plug》MarkSet #高亮或反高亮一个单词
nmap md 《Plug》MarkClear
nmap mn 《Plug》MarkSearchAnyNext #跳转到任一下一个高亮单词
nmap mp 《Plug》MarkSearchAnyPrev
nmap mf 《Plug》MarkSearchCurrentNext #跳转到当前高亮的下一个单词
nmap mb 《Plug》MarkSearchCurrentPrev
安装 goimports
[root@localhost src]# cd /root/go/src
[root@localhost src]# mkdir golang.org
[root@localhost golang.org]# mkdir x
[root@localhost golang.org]# cd 。/x
[root@localhost x]# git clone https://github.com/golang/tools.git
[root@localhost x]# cd 。/tools/cmd/goimports/
[root@localhost goimports]# go install
使用方法:在 vim 的命令模式下输入:GoImports
注意:在 tools/cmd 下还有很多命令工具,可以使用同样的方法安装
安装 golint,对 go 代码进行 lint 检查
[root@localhost golang.org]# cd /root/go/src/golang.org/x/
[root@localhost x]# git clone https://github.com/golang/lint
[root@localhost x]# cd 。/lint/
[root@localhost golint]# go install
使用方法:在 vim 的命令模式下输入:GoLint
让 vim 支持 gocode
[root@localhost vim]# cd /root/go/src/github.com/gocode/vim
[root@localhost vim]# 。/update.sh
如果还需要安装其他的第三方库,请按照下面地址去学习
https://www.golangtc.com/download/package
这里就不一一演示了,所有操作和上面的都是一样的了
最后的~/.vimrc 的文件是这样子的
call vundle#begin()
Plugin ‘Shougo/neocomplete’
Plugin ‘Shougo/neosnippet’
Plugin ‘Shougo/neosnippet-snippets’
” NERDTree config
autocmd bufenter * if (winnr(“$”) == 1 && exists(“b:NERDTreeType”) && b:NERDTreeType == “primary”) | q | endif
“ mark config
nmap 《F8》 :TagbarToggle《CR》
‘ctagstype’ : ‘go’,
‘kinds’ : [
‘p:package’,
‘i1’,
‘c:constants’,
‘v:variables’,
‘t:types’,
‘n:interfaces’,
‘w:fields’,
‘e:embedded’,
‘m:methods’,
‘r:constructor’,
‘f:functions’
‘sro’ : ‘。’,
‘kind2scope’ : {
‘t’ : ‘ctype’,
‘n’ : ‘ntype’
‘scope2kind’ : {
‘ctype’ : ‘t’,
‘ntype’ : ‘n’
有时间再补充下各个插件是怎么使用的吧。
安装 ack,这里是新补充的
[root@localhost kingshard]# yum install -y ack
[root@localhost bundle]# git clone https://github.com/mileszs/ack.vim.git ~/.vim/bundle/ack
在~/.vimrc中添加插件位置添加 Ack 和在文件最后添加快捷键 F4
Plugin ‘mileszs/ack’
map 《F4》 :Ack
光标停留在某函数或变量名上,按 F4 回车,即可全局搜索调用处
总结:可能会经常使用的快捷键
打开目录窗口:F7
打开符号窗口:F8
各窗口间的相互跳转:ctr+w+w
跳转到函数定义处:gd
向前:tab 键
向后:ctr+o
高亮光标所在的单词:ml
取消光标所在单词的高亮:md
下一个高亮的单词:mf
上一个高亮的单词:mp
转自:blog.csdn.net/pei2215015/article/details/79802351
责任编辑:haq
