基于SCM的物流管理原型系统设计
消耗积分:0 | 格式:rar | 大小:322 | 2009-02-28
分享资料个
根据供应链管理的原理和方法,以某离散型制造企业的物流系统为对象,构建了供应链结构。在此基础上,分析了物流管理流程,对原型系统进行了建模,采用C/S与B/S的混合结构方式,设计了物理管理原型系统的体系结构。用VB开发工具对工装管理子系统进行了设计和开发,开发的软件已在原型工厂的实际管理中使用。
关 键 词 SCM; 物流管理; 原型系统; B/S; C/S
Abstract According to SCM principals and choosing a mechanical manufacturing plant as prototype, the architecture of the plant’s supply chain is given out. The logistics is analyzed in detail by means of SCM concept and the model of the logistics management prototype system is established. The prototype system is designed adopting B/S and C/S mixed architecture. The tool-setup management subsystem is developed by VB language tool. The subsystem has been successfully used in this plant.
Key words SCM; logistics management; prototype; B/S; C/S
评论(0)
发评论
下载排行榜
