LED4020RGB幻彩灯珠的应用及参数
The application of LED4020RGB magic lantern beads and parameters
4020RGB幻彩灯表
Product Presentation (产品介绍)
● 特性 Features:
1. 控制IC与RGBLED芯片集成4020封装可正贴与侧贴。Control IC and RGBLED chip integrated 4020 package can be front and side stickers
2. OUT R/G/B输出灰度等级:256级。OUT R / G / B output gray level: 256 levels
3. 内置高精度及高稳定振荡器。Built-in high precision and high stability oscillator
4. 单线数据串联传输,可无限级连。 Single-line data transmission in series, infinitely cascadable
5. 级联数据整形后输出,防止数据衰减。 Cascaded data output after shaping to prevent data attenuation
6. 数据传输速率:800Kbps。Data transmission rate: 800Kbps
7. 每秒30幀时不低於1024级连。No less than 1024 level connection at 30 frames per second
8. 同一帧显示数据同步刷新。 Synchronous refresh of display data in the same frame
1. LED幻彩软硬灯条,LED全彩模块
LED Symphony soft and hard light bar, LED full color module.
2. LED护栏管,LED外观/情景照明
LED guardrail tube, LED appearance / scenario lighting.
3. LED点光源,LED像素屏LED异形
LED point light source, LED pixel screen LED shaped.
4. 各种电子产品,电气设备跑马灯
Various electronic products, electrical equipment marquee.
        ymf
