新品快讯
Maxim unveils a pair of RS-485 transceivers that integrate switchable dual-termination (100Ω/120Ω) resistors to enable remote network configuration, thus enhancing scalability.
RS-485 transceivers have software-/pin-selectable dual-termination resistors.
SUNNYVALE, CA—June 15, 2010—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX13450E/MAX13451E, RS-485 transceivers that integrate software-/pin-selectable, dual-termination (100Ω/120Ω) resistors to simplify RS-485 network configuration. These transceivers are well suited for industrial control equipment, IP camera installations, and other RS-485 network applications.
High-speed RS-485 networks require termination resistors at the end of each transmission line. This means that users must manually terminate the end-slave device through an external resistor or DIP switch each time they configure the network. By integrating switchable termination resistors, the MAX13450E/MAX13451E allow users to easily configure the network solely through software. This avoids the process of manual termination, thus enhancing RS-485 network scalability. Additionally, the integrated dual-termination resistors support both 24AWG and Cat 5/Cat 6 cables without the signal integrity problems associated with competitive solutions.
Both devices integrate a low-voltage logic interface (down to 1.62V) to support small-geometry ASICs/FPGAs without the need for additional parts. The MAX13451E has a fault alarm indicator to protect the system against driver errors, and the MAX13450E features a logic-inversion function to reverse the A-B signals in case they are connected incorrectly. Pin-selectable slew-rate limiting improves EMI performance, while robust ESD protection (±30kV, HBM*) and an automotive temperature range protect against harsh industrial environments.
The MAX13450E/MAX13451E are available in a 14-pin TSSOP package and are fully specified over the -40°C to +125°C automotive temperature range. Prices start at $1.89 (1000-up, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6300 products serving the industrial, communications, consumer, and computing markets.
