powercfg_在Windows 7中使用PowerCfg评估电源效率
消耗积分:0 | 格式:pdf | 大小: | 2022-01-11
分享资料个
powercfgIt’s quite annoying when you have work to do on your laptop and the battery is dead or low on power. Even if you’ve selected the Power Saver plan, there could be other factors causing the batt...
评论(0)
发评论
下载排行榜
